Old 09-27-2003, 11:33 PM
chuckhatch chuckhatch is offline
5th gen zc?
can i put a zc motor in a 5th gen hatch...is it obd 1 i cant figure it out ...?would i have to use a d serious trans from 92-95 ?
Old 09-28-2003, 11:02 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: 5th gen zc?
Yes you can as long as you get a OBD I ZC. Basically they are D series, just with a different stamp. You can use any D series tranny.
Old 09-28-2003, 11:58 AM
HMImports HMImports is offline
Send a message via AIM to HMImports
I was reading something that said the ZC had alot of troubles ;passing emissions, this ture? and also the ZC is primarily a 4 gen civic swap no? that would mean cable tranny, if u have a 92-95 u have hydrolic
Old 09-28-2003, 01:55 PM
Re: 5th gen zc?
ZC's ran from OBD 0 to OBD II SOHC and DOHC, and can be smogged as well as any other JDM, EDM, whatever engine. If you run the correct ECU, and smog equipment (cat, header, ehaust, sensors, etc...) you should be fine.
Old 09-29-2003, 01:03 AM
ive also heard that the ZC has little after market support. once again im new so i take everything i read as truth intil proven false
Old 09-29-2003, 01:07 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
the ZC is primarily a swap for the 88-91 Civic/CRX, but that doesnt mean you cant do it in a 5th gen. If you dont want to do a cable to hydro conversion, you will want to get a 92-95 EX/Si tranny (for better gearing anyways)
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Anyone miss the remote windows from the 4th gen since you bought the 5th gen? 2001 AE Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 10 08-06-2003 05:01 PM
5th gen coupe door panels in a 5th gen hatchback? emadboy200 Car Audio 2 06-09-2003 06:41 PM
5th generation accord v6 vs 5th gen accord 4cycl david90 Accord/TSX/Accord Hybrid 2 11-09-2002 02:14 AM
Zc swap in a 5th gen. Hatch Poweredbyhonda '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 02-19-2002 04:52 AM
glovebox guages/6th gen console in 5th gen civic j.fuggi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 12-17-2001 09:36 AM
