Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 09-27-2003, 09:52 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
I know all about starters/security ect. ask
I really do know a lot about vehicle electronics. If you have any questions, I will answer them from what I know. If I do not know the answer, I will tell you and then research it. I am not big-headed, just know my sheet
Old 10-02-2003, 02:32 AM
luckystrike luckystrike is offline
Re: I know all about starters/security ect. ask
Is it possible for my led in my remote to work, but not have enough juice for the locks and alarm to work?
Old 10-02-2003, 06:28 PM
Re: Re: I know all about starters/security ect. ask
Well sort of. See, the LED lights require very little juice for them to light. Again, the remote requires very little to transmit so it should work if you are close enough.
Did you notice your range getting smaller and smaller or did it just quit? What kind of alarm is it? You might be out of sequence. Try holding down the remote lock/unlock for 30sec. and see if it catches back up.
Old 10-18-2003, 03:42 PM
TheGreat TheGreat is offline
Send a message via ICQ to TheGreat Send a message via AIM to TheGreat Send a message via Yahoo to TheGreat
Sup, how do u reset the factory alarm on a 1991 g20 mines buggin out.
Excellence is my Presence
Old 10-19-2003, 04:27 PM
Well most of the time I see with Infiniti and Toyo vehicles is that the pin switches go bad. Some have trunk and hood switches along with normal door switches. You can try by first paying attention to your domelight to see if it comes on by itself or unplugging the trunk or hood sensor.
If you want to disable it completely, look under the dash to the theft module. The factory disarm wire is green/yellow. Make sure if you take that wire permenately to ground that it doesn't keep the domelights on.
I had to do this on a brand new Kia Sportage. It was the hood sensor setting it off.
Old 11-21-2003, 11:07 AM
gsrlbs gsrlbs is offline
I have a 92 G20, the factory alarm is randomly not letting me start the car, along with other problems. It seems to be pretty well integrated with 2 warning relays, pins for each door, trunk and hood. It doesnt have a remote it just gets activated with the key. So basicly every time you lock and unlock the door or put the key in the ignition it activates or deactivates the alarm. I just want to be able to turn the damn alarm off, is it as simple and just pulling the power to the alarm unit? or will that cause more problems?
Old 11-21-2003, 06:03 PM
If you have these problems, look in the driver's door boot. It's either a short in the disarm wire or the switch that sits on the lock mechanism is going bad. You might want to try the pass. side when this happens. I think you can disarm on either front door???
Old 11-23-2003, 03:10 PM
teaves teaves is offline
my security system is locked up. car won't start.
please help me. My security sytem has somehow locked up. can you help me on how to fix it? My car will not start at all.
Old 11-23-2003, 03:12 PM
help me please. My lexus wont start. the security system is locked up. Can you please tell me how to fix it.
Old 11-23-2003, 06:33 PM
I need to know what kind of alarm it is.
Old 11-24-2003, 04:59 PM
93G20DET 93G20DET is offline
Disabling Factory Alarm
I have a 93.5 G20 and I am installing a python 660XP alarm in the car. How do I disable the factory alarm, so I am able to install the aftermarket alarm?
Also, do you have any recommendations on additional modules or anything I should add to the alarm system for security?
Old 11-24-2003, 05:31 PM
I tried that, it doesnt work, I found the theft control unit and pulled the harness completely but that didnt work either, theres no room to be able to see which wire is which to disconnect it
Old 11-24-2003, 09:03 PM
Re: Re: Re: I know all about starters/security ect. ask
I never said it was easy to find. You might want to find a good local alarm shop that would be willing to look at it???
ANybody know anything about remote starters SlugHog F Series 0 08-21-2010 01:12 PM
Questions about car security h3llfir3 Engineering/ Technical 3 07-06-2009 01:54 PM
Did I kill my starter, please read if you know anything about a cars starting system. miata1.6 Technical 11 07-23-2006 04:59 PM
Anyone know about starters? 3000GT_Formula_350 General 0 07-10-2004 08:40 PM
