Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-27-2003, 04:20 PM
Rang73 Rang73 is offline
Exclamation flasher unit
Can anyone tell me where the flasher unit in a cutlass ciera 88 is and how to get to it? I have took apart the dashboard and can't see a flasher unit!! My user manual says it should be attached to the steering column, I can't see anything like the flasher unit I have to replace it, What does it look like?
Help please
Rang73
Old 09-30-2003, 10:10 AM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Flasher unit? Um.....what exactly are you trying to find? The switch that activates the directional signals?
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 09-30-2003, 04:38 PM
Thumbs up flasher unit
Thanks for the reply, yes its the unit for directional signals, my bulbs are new, hazard lights work but can't get signal lights to work.
Old 09-30-2003, 09:33 PM
Re: flasher unit
Just to clarify one more time...it's the switch on the column that is malfunctioning..correct? If so, then you have to remove the steering wheel to get at it. You will need a steering wheel puller for this job.
Old 10-01-2003, 02:58 PM
flasher unit
Hey thanks,
I already took the steering column apart and replaced the plastic 'thing' with wires coming out of it, everything else on the steering column works, someone told me somewhere in the dash there was a 'flasher unit' and I bought a part that is circular, about and inch in diameter and about and inch tall, it has a couple of pins at the base to plug it in somewhere, I can't see anything like it in my car and was wondering if there is a place for it, also from grounding the wires I got the signals to work but there was no 'clicking' as each light flashed, Do you think it is a in car computer problem?
thanks much
Old 10-01-2003, 10:06 PM
Re: flasher unit
I do not think it is a computer problem. The computer has no control over the flashers. I understand which part of the system you are talking about now though. The flasher "solenoid" can be located in one of two places. I know where it is on my Grand Prixs..but it may vary on the Cutlass'. They are the same platform, but their wiring was a little different for some reason.
It can either be clipped to the end of the steering column, or in an underdash fuse "array". Either way, you have to remove the kick panels on the driver's side. Those panels would be the ones located by the driver's feet. Once they're removed, you should be able to see it in one of the two places I mentioned....I hope Good Luck
Old 10-02-2003, 12:40 PM
Talking Found The Flasher On '88 Olds Cutlass Ciera!!
FOUND IT!!!! The flasher is located above the black diagnostic connector, facing the rear of the car. I got in on my back and looked around...it was behind a bundle of wires resting inside a little black clamp above and behind the connector. When I tugged on the wires the flasher unit slid out. Hopefully this will be helpful to someone else if needed. THANKS FOR ALL YOUR HELP!
Location of signal light flasher units GoinAllTheWay Cavalier 18 01-01-2005 06:48 PM
1993 Turn Signal Flasher Unit/Cruise Control Problem docfisher Bonneville 1 03-11-2004 06:19 AM
S10 Turn Signal/Flasher unit location Kmaxhhi S-10 4 01-17-2004 05:26 PM
flasher unit location sbabb425 Villager 1 12-29-2003 06:47 PM
Flasher unit location timdewolf Bonneville 1 03-03-2003 06:27 PM
