Old 09-27-2003, 04:04 PM
rgard32 rgard32 is offline
96 3.0 caravan....Are they Valve benders?
when the timing belt breaks....are thes motors valve benders? .,....the mechanic says they are bent....and i have doubts.....
Old 09-28-2003, 04:51 PM
granguzs granguzs is offline
Send a message via MSN to granguzs
valves bent
the only way to tell if u have a bent valve, is to run the engine,
Old 11-14-2003, 09:29 AM
yale329 yale329 is offline
Re: 96 3.0 caravan....Are they Valve benders?
This goes for any vehicle. Its the big if! If its a timing belt wich is much like any other belt on your vehicle the answer is not likely. If you have a metal timing chain the chances are greater that you bent a valve. Reason being a chain, much like a bicycle chain is metal, usually jumps a couple of cogs when worn, causing your crank and valve train to jump around in a very un-orderly manner. In other words theres no give.
91 mighty max 3.0 parting out Rip_Jeff Mighty Max 0 07-27-2010 06:04 PM
89 Voyager Valve Train 3.0L Nate1169 Caravan | Voyager 0 09-12-2009 01:11 AM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
92 3.0 Caravan Stalling Issue john2459 Caravan | Voyager 3 03-26-2005 02:43 PM
A/C compressor removal on 3.0 caravan nadeem72 Caravan | Voyager 0 08-02-2004 11:54 PM
