Old 09-27-2003, 12:25 AM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
Unhappy radiator repair
my radiator cracked like 4 weeks ago and if fixed her up with some jb weld, but now i see that its not holdin up and crackin through the jb weld jb weld must not hold up to the heat or pressure, does anyone know if theres anything else to fix a radiator, i know theres repair places but the closest one is 2 hrs away and was wonderin if theres anything that u can do urself?
it better get me to wyoming
Old 09-27-2003, 10:11 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the company Permatex makes a radiator repair kit, but its only for fairly small sized holes, prolly not bigger than a 1/2" check it out, you can find it at your local auto store.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-27-2003, 10:19 AM
ne0h74 ne0h74 is offline
this is why i took my stock air filter assy off! when i worked in my parents shop i would see at least 1 out of 15 honda's cracked right where the air filter assy attatches to the radiator.not a good idea with a plastic top radiator.
i was thinking about taking a soldering iron to mine. but i know from previous sheet metal expieriance you have to stop drill the ends of the cracks or they will spread. use a small drill bit and drill a hole on one end of the crack, then the other. this relieves the internal pressure caused by the crack and keeps it from spreading. Then i would fill it with high temp epoxy, and then take my soldering iron to it to cotorize the top.
Old 09-27-2003, 12:17 PM
i will look into that repair kit, the crack in the radiator is were the air filter thing is connected, its a hair line crack about 4 inches long, just enough to lose pressure and some fluid
Old 09-27-2003, 12:34 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i tried jb weld once too i ended up having to fix it on the side of the road with electrical tape to make it home, lol.
we need to fix a crack in hooptie's rad. top so we picked up some stuff called "QuickSteel" made by CarGo. it says it's good for:
-gas tanks
-radiators
-blocks
-tailpipes
-mufflers
-intake manifolds
-batteries
-stripped bolt holes
-body rust areas
plan to use it tomorrow. i'll let you know how it works
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-27-2003, 01:23 PM
BullShifter's Avatar
Re: radiator repair
Better yet, just replace the radiator & fix it properly. Not temporary fix. I just got a new radiator for my '91 civic Si last week for $75.00. If you want a new one I can get one for you - $100.00 + shipping.
Old 09-27-2003, 01:42 PM
amy@af's Avatar
not speaking for everybody but i used jb weld on my radiator because i was waiting for a new one in the mail and still needed to drive my car. i plan to use it tomorrow because the hole is less than a 1/4"....it barely leaks.
i am actually curious if the QuickSteel will work tomorrow. if it does i might just keep it in the car. if it does all that it says then it might be good to have for "just in case"
and FYI...you can get a brand new radiator from RadiatorBarn.com for as low as $94 (and some change) shipped. i have gone through them before and can say they have fast service
Old 09-27-2003, 03:00 PM
yea let me know if that quick steel stuff werks and where u can get if u know
Old 10-01-2003, 11:38 AM
shoddygoods shoddygoods is offline
i fixed mine with JB weld about four years ago and its holding just fine, i scraped out the crack in a little "v" to give the jb weld a little more to hold on to and after the first bit i put on set up i added another layer and a little brass sink screen to give it some dimentional stability.
its not pretty but it sure did the job...
Old 10-01-2003, 12:03 PM
amy@af's Avatar
Re: radiator repair
found it at wal-mart. put it on the rad. it went on good...looks like it will hold. but then we didn't use the rad. so i can't say if it held up. says it's good for 500 degrees. you might want to give it a try. it comes like clay kinda and you kneed it til it blends to 1 color then apply. pretty simple.
Old 10-01-2003, 10:38 PM
yeah i went out and got some last sunday cause i needed it fixed quick, and put it on, its werked so far kinda think itll last cause its rock hard and pretty durable, doesnt soften like the jb weld did when the radiator gets really hot
Old 10-01-2003, 11:29 PM
Re: radiator repair
If your gonna half ass repair it like that, at least do not tighten the radiator cap so full pressure doesn't build.
Old 10-02-2003, 06:56 PM
amy@af's Avatar
Re: Re: radiator repair
c'mon. lighten up, please. you call it half ass but you really don't know. there are situations where a new radiator isn't required. if he had posted a pic of a big ass crack then i would agree. but none of us know what the story is.
i do agree with avoiding full pressure if it was half assed. but wait....that doesn't mean leave it loose enough to spew fluid (lol)
Old 10-02-2003, 10:46 PM
haha if i had a picture of it it would eb halfed ass but it werks and i dont wnat to spend 80 bucks on a new one id rather spend 5 cucks to fix it
Old 10-03-2003, 01:30 AM
Re: Re: Re: radiator repair
Im just saying leave the cap 1/4-1/2turn loose to prevent full pressure. This way your repair is less likely to fail. If its gonna over-flow it should go in the over-flow tank.
cracked camry radiator repair jstrummer Camry/Camry Hybrid/Vista 17 01-30-2011 05:36 PM
Radiator repair? mikeemon Engine and Transmission 5 06-20-2008 12:53 PM
Self Radiator repair? Tommy in Brooklyn 1st Gen 95-99 5 09-22-2006 11:18 PM
Radiator repair jsgold Corsica 0 04-05-2005 08:54 PM
Broke_as_****'s half-assed one hour guide to radiator repair Broke_as_**** 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 12-04-2004 07:45 PM
