Old 09-25-2003, 07:51 PM
hotasshonda hotasshonda is offline
Send a message via AIM to hotasshonda
Axle Bind
ok well i just purchased another hatch...this one came w/ a b16 in it but needed some work. A new tranny so i did that this past weekend and its working pretty good. but when ever i make a right hand turn it vibrates. i talk to the kid i bought the car off of and he said its axle bind. he said there is no way to stop it on the 4th gens. he said it has i think 91 integra axles. so im not sure if that has sumething to do w/ it or whats up. ive ridin in a hatch a b16a and it didnt do it so im just wondering what it is. thanks for any help
Current Mods:
B16a, I/H/E, Coil overs, Shocks, Integra Front Suspension, Cross Drilled Slotted Rotors w/ Green Stuff Pads, Short Shifter.
**System**
Pioneer 6500 HeadUnit
MB Quart Component Set-Front
Boston Acoustics-Rear
Old 09-25-2003, 07:56 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
if he used the wrong axels it will not work properly... also if he used an inproper half shaft this will happen as well.
the Y1 transmission came with a Slightly longer half shaft than the YS1 A1 or S1.
My setup is a S1 tranny with an A1 Half shaft and 90-91 axels work fine. now depending ont he transmission he has this may not work... check the HASport website for the Lowdown on Axels.
www.hasport.com
Kun
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 09-25-2003, 08:00 PM
it had a y1 tranny it but when it blew the kid gave a 91 integra trans w/ it so i just threw it in until i get a new y1. so could the trans be the problem? he said it did it before w/ the y1.
Current Mods:
**System**
Old 09-25-2003, 10:15 PM
Kunundrum's Avatar
no the tranny is not the problem the half shaft is go buy a 90-93 teg half shaft and pop it in... this should fix your problem.
chanses are you are using a Y1 half chaft that is a little longer than the regular Teg one.
Leaking Front Axle Seal (With Pictures) wagslick Silverado 10 11-27-2010 08:14 AM
Oil capacity of GTS rear axle 2006GTS GTRA / GTWS / GTS 2 10-01-2010 07:46 PM
01 Denali front axle binding realjoe2000 Yukon 0 03-16-2010 05:37 AM
Stuck Inner CV Axle - 93 MX6 - Help Please! ziggy414 MX-6 0 11-29-2009 09:24 PM
b16 crx axle binding wickedplastikman Wheels/Tires/Suspension 4 11-20-2004 02:58 PM
