Old 09-25-2003, 03:23 PM
oldaddie oldaddie is offline
how do i set timing/ install distributor on 97 350 vortec?
assuming it's totally out of time, what spep by step actions do i take to restore proper operation?
Old 09-28-2003, 09:58 AM
ALdrkcloud ALdrkcloud is offline
if you took the distributer out the you might have it out. you will need to get a mirror and a light--look on the bottom of the dist. at the intake there should be a white mark on the dist. and intake, it will be at the back-thats why you need a mirror-if the marks are aligned--then it might be another problem
Old 08-08-2004, 01:14 AM
stubbornmike stubbornmike is offline
Re: how do i set timing/ install distributor on 97 350 vortec?
you would need to set the number one cylinder to top dead center. look at your distrubtor with the cap off put the rotor to the number six and eye ball the oil pump shalt it the same position... ( u need a long screw drive to turn the oil pump shaft) when u slide the disbutor in its slot you will notice the rotor is turning toward cylinder 1 if it doesnt slide in all the way turn the oil pump shaft just a hair intill the distrubtor is fully seated!
Old 11-15-2004, 09:31 AM
SSAV SSAV is offline
i have an 85 gmc that has lost all fire to spark plugs. i have put in a new rotor, coil distr cap and even tried another distributor. it has 12v going into distributor and around 9v while cranking. any help is great. thanks in advance
Old 11-15-2004, 11:03 AM
Thunderbolt Thunderbolt is offline
The only real way to set the timing on a 97 is with a scanner. It needs to be 0 degrees plus or minus 2 degrees. You can get it close by bringing the number one cylinder to top dead center on the compression stroke, place a mark on the dist. housing where the number one terminal is on the cap, remove the cap and turn the distributor until it lines up with the mark. It will be close and may or may not be within the specs. The only way to know for sure is with a diagnostic scanner.
Old 11-15-2004, 01:28 PM
skipr skipr is offline
Re: Re: how do i set timing/ install distributor on 97 350 vortec?
I bet you it's the solid state module inside the HEI distributor. It leaves you completely dead when goes out, $10 part.
Old 11-15-2004, 05:08 PM
LT1 Kayker's Avatar
LT1 Kayker LT1 Kayker is offline
Send a message via AIM to LT1 Kayker Send a message via Yahoo to LT1 Kayker
Don't forget to disconnect the ECM signal wire before you do the distributor base timing. (when you loosen the nut and turn the entire distributor by hand) It turns the timing advance and retard along with the knock sensor off and then resets when you plug it back in. If you don't do that it will be set at the right timing, but the computer will think its still at its old spot and advance and retard right back to the old setting.
89 Chevy C1500 - Over 305,000 miles on her but still going strong.
Cut off cat/straight pipe.
Flo-Pro muffler. (Flowmaster soon)
Dual 3" tips.
custom intake.
chrome valve covers.
uhhh and im poor so thats all haha.
Friggin truck costs more to keep alive than I do. (4ishMPG no joke)
Wait, let me get this straight...Your honda has 1.6 liters, but my bottle of Mountain Dew has 2!?
Old 11-15-2004, 05:15 PM
LT1 Kayker's Avatar
Forgot about the wire. On most Chevy SB's it's near the firewall on the passenger side. should be a tanish wire with a white trace on it. It leads to a small black box that you should be able to find pretty easy, but it is kinda hidden on the lower side of the block.
Dual 3" tips.
custom intake.
Old 11-16-2004, 03:40 PM
The wire you are refering to is only on the pre vortecs as far as I know.There is no wire to disconnect that I know of on the 96 and up trucks. I didn't on mine when I did it, I just plugged the scanner in and set it to zero.
2000 GTP - how to re-install harmonic balancer Van2000GTP Grand Prix 1 02-24-2010 07:44 PM
2002 Distributor Install Procedure wmako M Bodies 2 02-02-2010 10:16 PM
350 vortec timing issues? chipp3rwood C/K 2 06-27-2009 10:41 PM
1995 Blazer 4x4, Re-Install Distributor, Help to set timing pls. TDC, BTDC sneakers98 Problem Diagnosis 3 08-14-2007 09:55 AM
99 350 Vortec Timing redlion Suburban 9 12-14-2004 07:00 PM
