91 CRX 2-3 grinding
guys I just bought a CRX with a 1.6 Vtec Twin cam engine,its from a japanese civic.The problem is that my transmisionn grinds from 2 to 3 unless I sort of hesitate and kind of push it a little towards 4th gear before shifting to 3.But if I shift directly from second to third it will grind.I need your help,is it the syncro?
Seems like it would be the 3rd gear/synchro. If you remove the trans & open it up, you should replace all parts needed. What you will need? Who knows until you tear that bitch open. If your tranny is in need of a rebuild I suggest looking a rebuilt tranny - mine came with warranty & was only $300 or so.
You should hesitate no matter what, tranny is not built to be slammed or shifted very quickly. Also your shifter is not a hand rest, resting your hand on the shifter can cause pre-mature wear! |
Thanks,Is there anything that I shoud check before to rule out other possibilities,maybe a misadjusted tanny cable or something.I,m no mechanic but I want to rule ouut anything else before tearing down the tranny
Re: 91 CRX 2-3 grinding
You could try adjusting the clutch cable
drain out tranny oil, put in gm syncromesh friction modified, 2 quarts, bam grinding gone. should be in square bottle, not round. go to your local gm dealership to get it
The 3rd gear grinding is a very common problem in 4G Civics.
Welcome to AF.. You can also get GM synchromesh here....the dealerships want $9+ for a quart of that stuff. http://www.gmpartsdirect.com/
-Shawn '91 Civic DX sedan DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Thank youy very much guys ,I will try the syncromech and check the adjustment of the clutch too,I wont be getting my car for a few days or so since is in the bodyshop getting a some detailing work done,but I wil tell you khow everything goes after getting it back,Thanks for all the help
good luck finding a rebuild kit for a cable b16a tranny stateside |
Thats why I typed ^^^^^^ that. |
