Old 09-22-2003, 10:47 PM
Kayleigh Kayleigh is offline
Need info on OBD II Codes
My 97 Isuzu Rodeo has the following codes that come up.
P0101 - Mass or Volume Circuit Range Performance Problem.
P0401 - Exhaust Gas Recirculation Flow Insufficient Detected.
From what I've been able to determine so far, that this has something to do with the Air intake and Exhaust/Emissions, but I've not been able to track down any specific parts that need replacing.
Any assistance on this issue would be greatly appreciated.
Old 09-23-2003, 09:06 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: Need info on OBD II Codes
It's referring to the circuit that measures the mass or volume of air flowing into the engine. Check the MAF (mass air flow) sensor, if your car has one.
EGR Flow Insufficient - your EGR valve isn't letting enough exhaust into the intake system, or the flow is obstructed somewhere. Check the following:
Control input to EGR valve
EGR valve response to input (does it open?)
Unobstructed flow path (no carbon buildup) to and from valve
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 11-18-2003, 09:49 AM
shotgun361 shotgun361 is offline
always take care of the lower numbered code first.
Diagnostic help needed w/ OBD codes maxxxx Beetle - New/New Beetle Convertible 10 12-30-2005 09:27 PM
OBD code info...... nosefirst Tahoe 0 08-18-2005 10:18 AM
Need an OBD Code confirmation Kings-x59 Durango 6 03-06-2005 07:05 AM
need help with obd code p01710 mressa 7 Series 0 11-08-2003 10:19 PM
