Old 09-22-2003, 03:02 PM
jafowler49 jafowler49 is offline
What temp your bird run at?...
My 89 Trans Am GTA runs at about 220, or the middle of the meter. The meter shows a little over 220 but i think thats because the meter's not completely accurate. On the freeway it goes down to about 180. Does this seem correct. The mechanic said it was right, but it feels a little hot.
Old 09-22-2003, 05:04 PM
pre pre is offline
Third gen f-bodies(82-92 camaros and firebirds) run pretty hot. Get a 165 degree thermostat and make your fan run all the time or a switch to turn it on when you want.
Old 09-22-2003, 10:48 PM
What does that do? Just rebuilt engine and said it runs fine, but I think I could run cooler? Happen to know how much it costs?
Old 09-23-2003, 10:49 AM
Cornholio7979 Cornholio7979 is offline
Not all birds are hot
My 89 Formula 305 TBI runs at 140, or if I make it sit in one place and run, it will move up to 220 when the fan comes on and brings it down to 180.
Old 09-24-2003, 06:23 AM
rodrigfr rodrigfr is offline
low coolant water indicator stays on.
when the light comes on the temp is about 210 and stays about there. but about a year and half ago the wife took the car to the shop because the thermostat malfuctioned. i noticed some white residue on the refill water stick. could the sensor inside the refill bottle dirty???
Old 11-17-2003, 02:30 PM
Dalusa's Avatar
Dalusa Dalusa is offline
Send a message via AIM to Dalusa
i used to run at like 210 then i got the 160 and i run at like 180. BUT then i got the ground effects and it actually made the car run a little hotter....but the few degree increase is worth the look of the car...see for yourself...
______________________________________
Best 1/4 mile time 12.68 @ 128mph
386HP 373Torque
Options:Sport Metallic Gold Ws6 Manual
Mods: Hooker competetion headers, Slp y-pipe, Slp LoudMouth Catback, b&m Short Throw, March Pully's, 80mm Throttle Body, Weiand Intake Manifold, Jet stage 2 chip, Slp 160 Thermo, Eibach pro kit, Slotted Rotors (F&B), Granatelli MAF, A-Pillar Guages-(Air/fuel Ratio, Fule Pressure, Trans Temp) Slp Skip Shift, Granatelli - Panhard Rod, G Load brace, subframe Connectiors, Strut Tower Brace, 200 MPH speedo, AFS ZR-1 Wheels (17X9.5-F 17X11-B) Sumitomo HTRZ Tires, Wings West ground Effects (Front only) E-mail or AIM for Dyno Sheet
Old 11-17-2003, 06:39 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Re: What temp your bird run at?...
How often do you scrape with the kit on there?....
Just for the Stroke of it...
Old 11-18-2003, 12:18 AM
MRWSM's Avatar
MRWSM MRWSM is offline
Cooler thermostats are the way to go. I got one that is 160 degree. When sitting in traffic just turn on the AC even if it is in the winter and the fan will start a little sooner at about 200 degrees.
Old 04-03-2004, 08:54 PM
yoursuperman yoursuperman is offline
i had same problem with temperature i thought was really high but when i went and got it checked the guy told me for my 1991 formula that it was normal and that 260 wasnt hot for that engine . i still debate on that one but who knows ......
What is your Normal running temp? tuxx2 Camaro Discussions 12 03-24-2007 11:03 PM
What does your 4g Idle at? quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 15 10-12-2004 06:03 PM
What up guys? What are your cars running? 94CamaroZ28 Integra 3 07-21-2004 05:48 PM
what r your swaps dynoing at? imprtsyco '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 11-19-2003 01:10 PM
What Does Your Car Run In 1/4 Mile, And What Kind Of Car You Have? crxfanatic_88 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-01-2003 12:27 AM
