Old 03-21-2007, 07:39 PM
tuxx2 tuxx2 is offline
What is your Normal running temp?
I just replaced the farn and it seems to be spinning ok but now im all parnaoid about the car over heating.
What is considered "normal" for a 95 firefird that has been running in normal traffice for 30 min or so?
Is the gauge half way normal? 3/4 normal? Anything under red?
Thanks in advance for your help
Old 03-21-2007, 08:07 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: What is your Normal running temp?
Mine stays about half.
But the 99-02 LS1 F-Bodys have a 'dummy' gauge. Only really shows 3 temps. Cold, warmed, overheat.
So I added an electric coolant temp. gauge.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 03-22-2007, 08:25 AM
poormillionaire2 poormillionaire2 is offline
30 minutes sitting in summer traffic runs my temp way up. Haven't tried it yet with my new t-stat, but the stock one ran it almost into the red on my 94 Z. That's when you blast the heater on full. That helps alleviate some of the heat.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 03-22-2007, 08:42 AM
mrmartin23's Avatar
mrmartin23 mrmartin23 is offline
I just replaced my thermostat with a 160 and my average temp after @40mins on the freeway (rush hour, stop-and-go) is 210-220. When it is warm I blast the heater also. I hear that a drop induction air intake will also help cool and more performance as well. Shopping for one now .
Full time dad to 2, wife of 16yrs, San Diego Chargers fan, Formula-1 project and commander of my paintball group------- yeah i'm busy .
Old 03-22-2007, 01:12 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
When stock it was 210. Right in the middle. Sitting in the NJ summer hea in traffic.... it would go MAYBE to 230.
With the 160 degree thermostat and the comp tuned to turn the fans on around 170 - 175... at the very most it hits that 170-175
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 03-22-2007, 02:26 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
yeah mines is set to 160 or a little lower i think...but sum times down here its hotter than hell and it gets up there but not bad...
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 03-22-2007, 04:50 PM
mrmartin23's Avatar
Ok I need to ask this so remember I am very new to working on my own car please.
What do I need to adjust the comp settings for the fans?
Old 03-22-2007, 11:14 PM
Stealthy-One Stealthy-One is offline
Send a message via AIM to Stealthy-One
you need to get a new chip burned for the ecm.
Old 03-23-2007, 01:54 AM
unless you have a 4th gen, then it's a little different
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 03-23-2007, 12:19 PM
You have to change it through the PCM.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 03-24-2007, 02:47 PM
sreve sreve is offline
i bought an LS-1 '02 camaro last month. those gauges just seem to fill up space in the dash. put a hypertech *180 stat in it and it still read almost *210 at the gauge. though scanner said *190, high speed fan kicked on till it burped at*230 on the scanner but not much over *210 on the gauge.
if your car is '94 or newer 8cyl. and you are near the ST.L area pm me i can do it. PCM for less is also a good option
Old 03-24-2007, 10:52 PM
Yeah, the gauges aren't the most accurate on the 4th gen f-bodies.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 03-24-2007, 11:03 PM
Mr. Luos's Avatar
Firebird Guy
A very large understatement when it comes to the temp gauge.
The only year that was semi-accurate is 1998 for the LS1 cars.
The later years are even worse. They basicly have 3 levels on the gauge. Cold to warming, warmed, and overheating.
This is why I invested in an aftermarket coolant gauge.
Also...if you own a 160-180 degree thermostat in a 4th gen...you have to program the PCM to really utilize it.
My iron block LSx never goes over 220 degrees. Fan kicks on early though. If it was aluminum, it would be cooler.
You want your motor running 185-195 degrees for optimal performance/efficiency.
Stock'ish'
