what about this rebuild kit
found this on ebay and was wanting to get your insight on this. i am planing on rebuilding my 94 b18c1 just to stock performance. So how does this rebuild kits sound.
This is an after market made Honda Acura Integra or JDM or USDM B18A B18B B18c1 or b18c5 engine rebuild kit! It contains full complete gasket set + full set of Pistons Pins and Rings full rod bearing set full main bearing set thrust washers freeze plugs timing belt and oil pump All brand new! you cant find a better price on this quality engine rebuild kit! b18c1 b18c5 rebuild kit On Sale!! buy it now $459.99 This is the same exact kit we use in our remanufactured engines !!! THIS KIT COMES WITH PISTONS + PINS RINGS ROD AND MAIN BEARINGS THRUST WASHERS FREEZE PLUG KIT FULL GASKET KIT OIL PUMP TIMING BELT Gsr type-r Rebuild Kit On Sale!! BUY IT NOW!!! for $459.99 when you buy you must specify year and model also what size pistons + bearings you will want! fits JDM B18C1 GSR AND B18C5 TYPE R The full gasket kit includes all gaskets to rebuild the B18C1 OR B18C5 engine. It is a quality rebuild kit. 16 Valve DOHC 81 mm bore 87.2 Stroke auction is for kit to fit 94 to 2001 Integra with the b18c1 or b18c5 U.S.A or J.D.M. also B18A1 or b18b1 Don't waste your money buying from the dealer save big bucks and buy it here!!!! |
sounds like its pretty good. I had a buddy buy that same kit for his D16Z6. He really likes it and has had no problems since.
2004 Sonic Blue Ford Ranger XLT 2001 Liquid Grey Metallic Ford Focus ZX3 1995 Integra GS-R - Parting out |
uhh....not to sounds stupid, but what is so great about it? arnt you just putting newer stock stuff on your....ahem...already stock car?
not to sound like a ass but if you reread the post i said i was just and i quote and i did says this "rebuilding my engine back to stock performance" so yea you can feel stupid.
guess i shouldve read it more closely. My buddy got the one that had the high compression pistons with it.
How much did that one cost if you remember?
i think it was around $450 or so. In the auction he saw, you can choose between low compression and high compression when you win the bid.
Ok thanks for the info man much thanks.Good to know that someone out there has bought this rebuild kit.
