Old 09-21-2003, 05:02 PM
Milliardo's Avatar
Milliardo Milliardo is offline
Send a message via AIM to Milliardo Send a message via Yahoo to Milliardo
Lightbulb DIY Cam Timing Adjustment
Can adjusting the cam gear be done by yourself. and I mean safely without having to dyno it?
Admin of PGamers Forum
1993 Honda Civic ESi (Sailor Mars)
My wish list--I need help in this project: http://pikarod.fateback.com/car3.html
Old 09-21-2003, 05:27 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
It can be done, and it can be done safely. The real question is if you will gain or lose HP, that's why you need the dyno.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 09-21-2003, 05:34 PM
Milliardo's Avatar
Lightbulb
That's true, but since dyno here is expensive--only one shop here has dyno, and they charge you so much because of it--DIY seems to be the only alternative.
Old 09-21-2003, 05:46 PM
GundamExpo's Avatar
GundamExpo GundamExpo is offline
You need a dyno to see if your making hp gains or losses.
Old 09-22-2003, 03:40 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
i think you would be safe for now if you just did it yourself, just so the car ran. I dont think it could do anything that harmful really.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-24-2003, 03:46 PM
funkdaflex1 funkdaflex1 is offline
For every degree you retard or advance your timeing you have to double that amount to your ignition timing so say you advance your cam gear 3 degrees you have to advance your ignition timeing (with a timing light) by 6 degrees.
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 09-25-2003, 02:02 PM
Milliardo's Avatar
Lightbulb
Thanks for the replies! So, how do you exactly advance or retard timing? I see those hexagonal nuts on the gear itself--which way is it to advance and retard?
Old 09-25-2003, 03:50 PM
Buzz1167 Buzz1167 is offline
Send a message via AIM to Buzz1167 Send a message via MSN to Buzz1167
Coming from a purely mechanical point of view - Advancing would be turning the gear in the direction of motion, retarding would be going against the direction of motion. So if you look at it while it running, right before it starts or stops, you can tell whitch way its turning, then make note. They do make gears that make this alot eaiser, some of them have degrees marked off on the gears.
But since you don't have these, I would suggest you mark off the point its at now, so if you screw it up, you can go back. Just take a marker or some whiteout and mark across the bolt and the gear so you have something to line it up with later.
HTH
Buzz1167
Quad-cam Query?????? RVZ05 Escape | Maverick | Escape Hybrid 0 07-05-2010 05:47 AM
Timing Adjustment Question JAGSARGE F Series 4 05-31-2010 05:50 PM
Installing Cams. Cam timing???? boosted k20 Integra 2 08-15-2004 01:49 AM
Cam Shaft Adjuster KatrinaKS '94 - '01 3 05-14-2004 02:15 PM
price and risk of adjusting cam timing MaFi0s0 Engineering/ Technical 5 05-17-2002 01:23 PM
