I have a 96, 240SX, and i am planning on an engine swap, i already decided
to go with a s13 SR20DET engine clip, but i have the doubt of if the engines mounts have to be moved or replaced, this is my first time working on a nissan, and also are these engines dependable. thanks and please help me, and also what other things are needed for that engine swap. i need your help please.
I'm pretty sure its a direct drop in, and the engine is pretty reliable
1989 RX-7 TII --- Just got rebuilt and street ported RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II, 720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads HKS Blow-Off Valve, Stainless brake and clutch lines |
yup soyo is right.. its basically a direct swap.. it just the wiring from ka24de to sr20det can be a bitch.. other problems
relocating power steering pumo.. changing i\c if it is damaged or changin the downpipe if damaged.. also check the oil pan to see itz not damaged thru.. shippin.. pretty easy swap.. good luck 1
![]() Shift_BOOST 97 s14 |
