Old 09-19-2003, 03:30 AM
afroeman afroeman is offline
Send a message via AIM to afroeman Send a message via Yahoo to afroeman
F20A Motor Swap
Hey guys bimmer boys back, but this time no bimmer. I'm going to be getting a 1995 Honda Civic Si Hatchback with a B16A1 already in it. I'm wondering what you all think about doing an F20A motor swap. I know I'll need a rear-wheel drive conversion but is there anything else special I might need to have done in order to complete this swap. It's decided I'm doing this because it's something that has not been done before. that i know anyways. Plus it will make my little honda push about 265 horses to the wheels!!! Just looking for some input and recommendations and also maybe some pros and cons to doing something like this. Thanks in advance.
Old 09-19-2003, 07:33 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
i think you mean the F20C ... The F20A is out of the 90-93 Honda Accord....Anyways, to answer your question, ive never seen anyone do it because i dont think its possible. You could be one of the first people and give it a shot., but i dont think its worth it. IMHO, i would just leave the B16 in there. That motor has alot more potential than you think.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-21-2003, 04:09 PM
sihondasracer's Avatar
sihondasracer sihondasracer is offline
Send a message via AIM to sihondasracer Send a message via MSN to sihondasracer
haha
you do that and youll make every mag there is...take your car to SP engineering and see what they have to say..member these are the same people who threw a 2JZ-GTE into a RX7,...but i dunno if yuod have the funds..like he said b16 or b18 much better
i live for the feeling i get when i downshift and feel the motor scream up to 8000 rpm and pull on any unsuspecting victim with the fury that an old hatchback should never have.
Old 09-21-2003, 04:22 PM
carrrnuttt's Avatar
carrrnuttt carrrnuttt is offline
There is an F20 motor that can be fitted a lot easier: The F20B from the JDM Accord SiR-T. It's basically a de-stroked H22A that revs higher and puts-out more power at about 220HP.
2002_Nissan_Maxima_6-speed
Old 09-22-2003, 08:00 PM
Bambooseven's Avatar
Bambooseven Bambooseven is offline
you could do it, I don't even think it'd be as hard as everyone thinks it would be. I would do it in a EJ coupe though, there is already the hump there for the driveshaft. You'd have to make a mout inside the trunk (where the spare tire went) for the differential, use custom axles front and rear, modify the trailing arms to except the larger hubs, shorten the driveshaft, and figure out the motor mount situation (normal f motors are different then the f20c when it comes to mounting), etc. If you really wanted to have a one off car, do a NSX swap. Either way it'd be the same types of fabrication needed. It can totally be done, and i'd love to see it happen. I'd do it myself but i don't have the capital to do it. plan on $15-20k to make it happen, but your car would be world renown.
Hey if Top Fuel in japan can do a mid engine b18c delsol you could do this.
Old 09-22-2003, 08:10 PM
carrrnuttt's Avatar
Re: F20A Motor Swap
That's not even close to being as complicated as turning an FF into an FR. The mid-engine is a LOT easier, because the motor is already designed to be transvers-mounted, and you can even use stock axles for something like that.
Not saying his notion is not possible, but just not as doable as the example you stated.
Also, I doubt if 20,000 would be enough, as the F20C alone is close to 10,000-dollars already by itself. Maybe the fabrication and materials, especially if you do it yourself, but as a finished, running product, it's hard to see how 20,000 would be enough.
Old 09-23-2003, 04:41 PM
90CRXZCSi's Avatar
$10,000??? uhh...i dont think so. Right here its $4K...
http://www.hmotorsonline.com/shop/sc...age&item=30013
i say the total of the project is $12-15K.
Old 09-23-2003, 05:17 PM
I'll stick with $20k. and I don't think itd be as SUPER HARD as everyone thinks. It might not come out LOOKING pretty, but it'd work. DOing it in a hatch would be rediculous though (IMO).
MY CAR!
Old 09-23-2003, 05:42 PM
GundamExpo's Avatar
GundamExpo GundamExpo is offline
Putting that motor in a civic is such a waste. That motor was not ment for the likes of econo-cars.
Old 09-25-2003, 10:03 PM
ImportFool ImportFool is offline
Send a message via AIM to ImportFool
...i read an article about this a while ago, for one, when it comes to motor mounts ur screwed..the f20c is mounted longitudal, but with the right amount of money anything is possible, but i will say i highly doubt this will be pulled off n e time soon, cus i feel it is a waste of money...i dont see how it would be worth swapping in an s2000 motor into it...if ur lookin for a fast drag time...why convert it into rearwheel drive...when u can stick with the front wheel drive for better traction, why force urself into havin it rear wheel drive, becus of this swap???....with all the money u would be dumping into a s2000 motor..u should just invest it into the b16 u have...wit 20 grand invested into it, u would be spankin s2000's...
-ImportFool
Old 09-25-2003, 10:36 PM
carrrnuttt's Avatar
Re: F20A Motor Swap
Originally Posted by ImportFool
...why convert it into rearwheel drive...when u can stick with the front wheel drive for better traction...
Please tell me this was your ten-yr-old brother that got ahold of your computer, and posted this for you.
Old 09-25-2003, 10:46 PM
u would have to convert ur hatch into a rear wheel drive...like is said smart guy... i was bringin out the point....why would u dump over 20 grand into a motor wit 240 hp. and rear wheel drive...i was tryin to say that 20 g's is too much money for 240 hp. that u would lose traction with.....
-ImportFool
Old 09-25-2003, 10:49 PM
someone should really teach u how to use the quote feature...leavin out words or sentences can change the whole meaning....i said
"when u can stick with the front wheel drive for better traction, why force urself into havin it rear wheel drive, becus of this swap???"
notice the underlined sentence..
-ImportFool
Old 09-25-2003, 11:02 PM
Re: F20A Motor Swap
he wasn't talking about the rest of the qoute, just that part.
MY CAR!
Old 09-26-2003, 10:10 AM
what u think u getter better traction from rear wheel drive, ill tell u what u got another thing comin....or am i missin sumthing else?
-ImportFool
2002 Suburban - Motor Swap - Won't Start mrharris32 Suburban 5 09-22-2010 06:48 PM
help please !! motor build question!! Derrick12556 Mirage 2 12-27-2009 05:31 AM
Lemans motor swap xxGriffonxx LeMans 4 10-27-2009 08:28 AM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
