93 del sol (fuse box? help pls)
hi all:
i am looking to get the description of the dash fuse box for my new (to me) 93 del sol. here is the problem i am having: the right head lamp (passenger side) doesn't work as follows: high beam works but low beam doesn't. i checked the bulb and the connector by using new parts and they are not the problem; while doing this i discovered that the fog lights don't work either (the switch light does not come on); by looking in the haynes manual, there seems to be that they are linked to the same fuse (#21 if i remember right), but the fuse box depicted there does not match my car (how nice ![]() i checked some 10amps fuses, and the ones i checked are ok; maybe, i am missing a fuse but don't know where. pls help; thanks. neko |
is this what you're looking for?
What model is your Del Sol? The fuse layout may be different between the models.
Also, are you looking at the fuse box in the engine bay by the battery and air box or the fuse box under the dash on the left below the steering wheel?
![]() 1995 Honda CRX del Sol VTEC Manufactured: Suzuka, Japan Production Sequence #1269 Team Del Sol member #1131 HondaVision: Team Sol Forum - Home of Team Del Sol __________________ |
problem solved; thanks
hi all:
i was looking for the dash fuse box; got the plan from a dealer here in NVA (v friendly; they let me make copies of the pages i need); the #21 fuse was put in the #20 bay (which should be empty); changed and voila ![]() thanks again. neko |
Awesome. Good deal then.
