Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 08-23-2005, 01:04 AM
bigziggy99 bigziggy99 is offline
del sol window wiring help
i removed the interior of my 97 del sol to change the color. when i was done i put everything back in the car but i have no power to all 3 of my windows and to the light on the ceiling in the back. i checked all the fuses and cant figure out why i am getting no power. please help me out. thanks.
Ziggy
Old 08-23-2005, 12:42 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: del sol window wiring help
You could have possibly forgot to hook up a connector, or maybe pulled on one a little too much and pulled the wires from there connector. I would try removing some of the parts you took out again and retrace your work. If you don't find anything out of place, go get yourself a multimeter and with the interior already apart, start at the fuse making sure it has power and work your way to the non working components. An ETM would be really helpful too.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 08-23-2005, 04:12 PM
i am gunna give that a try. thanks
