Old 09-15-2003, 08:19 AM
dfaiman dfaiman is offline
Unhappy Heater Fan Will not Energize
Have a 91 Honda Civic EX, 1.6L, the heater fan will not come on, I have checked all of the fuses and they are good. Can the fan motor be checked without taking it out of the car?
Would any one have a wiring diagram for this car?
Old 09-15-2003, 06:33 PM
dan91SE dan91SE is offline
Grab a voltmeter and disconnect the fan's electrical connector. Jump the voltmeter wires to the connector. With the ignition on accessories turn on the fan and you should receive a voltage reading on each of the four settings (only last two speed settings work on mine.....a bad connection in the speed selector relay prevents 1 and 2 from working.....lol). If you get a reading on at least one of the four settings replace the fan ($7 CDN from my local junkyard about 2 years ago...). If you do not get any voltage readings you should probably replace the speed selector relay; but you should check all wires anyhow.
P.S.: Search the forum for the link to the helms manual and the suplement; it has the wiring diagrams you're looking for.
Old 09-16-2003, 02:00 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
check water coolant temp sensor too...simply take the sensor plug out then get a wire and connect both wires in the plug(kinda making a u shaped wire)...if the fan works then replace the sensor ($20) from the dealer maybe less.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
AC / Heater Fan speed Switch ibkafn8ed Cherokee 0 07-05-2009 02:26 PM
06 Expl Heater Fan stuck full blast/can't stop! Kirkwwhite Explorer | Explorer Sport Trac 3 04-02-2009 09:17 PM
1997 blazer heater fan does not run 57Chev Blazer 5 01-01-2005 06:53 PM
88 Cherokee heater fan does not blow. 88Jeepster Cherokee 3 11-09-2004 10:16 AM
cooling fan will not turn off ewgoodie Escort 1 07-23-2003 03:52 PM
