Old 09-15-2003, 12:35 AM
poison_ivey poison_ivey is offline
Send a message via AIM to poison_ivey
302 vs 351
whats the difference between those engines? is the 351W really a 5.8? also, what is each engine putting out on torque and hp. o and which would 'respond' better to mods like superchagers headers ect.
thx
Old 09-15-2003, 06:54 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
A 351CI motor is actually 5.75289 Liters.
Stock for stock, I would take the 302. Modified, I would take the 351. Both have many aftermarkert parts readily available, and both will respond well to mods.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 09-15-2003, 06:26 PM
ugly kid jon's Avatar
ugly kid jon ugly kid jon is offline
All i gotta say is I love the 302, high reving, awesome sound, my favorite engine of all time.
Old 09-20-2003, 04:14 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
302/351?
the 302 responds a LOT better to boost than a 351, especially stroked out.
Old 09-22-2003, 12:27 AM
Twyzz Twyzz is offline
Send a message via AIM to Twyzz
351..... stroked to a 408 *nuts* nothing imho will ever beat the engine. DSS has one with 600 hp.... Try getting that out of any stock and stroked 302. the 351 block is bullet proof. it can handle lots of boost, and i think they sound a lot better than a 302
Old 09-22-2003, 01:10 AM
um, in case u didn't know the 351 is the same block as the 302 bored w/ a taller deck height. and actually if u do some reading, almost every single 5.0 bracket racer out uses a 306, 331, or 347 with a custom high boost turbo system, intercooled. 408's are phasing out cause they just dont rev like a 302! Besides a 302 is a lot more streetable anyday.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 09-22-2003, 12:20 PM
boosted331 boosted331 is offline
Re: 302 vs 351
Incase YOU didn't know 351's are the same bore as a 302, taller deck height and half an inch more stroke. And saying almost every single 5.0 turbo racer uses a 306, 331 or 347 just isn't true. Lets look at NMRA, for example. Anybody in pro 5.0 using a 302/8.2 block? Nope. Anyone in SSO? Yep, because they're limited to 360 inches (most running 3.4" stroke 4.1" bore) and going to a 351W and adding that bit of weight doesn't make any sense. Lots of blower cars running 351's though. How about renegade? Once again, limited to 360 inches so not many people go for the extra weight of the 351. NMRA drag radial, here again 360 inch limit for turbos/blowers so most people go 302 or 8.7" deck, all the competitive nitrous cars are 351's. Real street is limited to a 302. Looking into FFW, any classes where turbos and 351W's are allowed, you don't see any turbo 302 cars.
Talking about a street car, 408's arn't the greatest for a turbo motor because they make so much torque you're going to blow the tires away, and with the big stroke the piston pin is pushed up pretty high so it's hard to get the compression under 9:1 with a cylinder head with less than a 70CC chamber. A 383 is a much better choice, you make more power per pound of boost than a 302, 306, 331, or 347, the motor will last longer than a 347 because the piston pin isn't pushed up into the oil ring and you still have a nice rod/stroke ratio, plus the motor will be a lot snappier when driving around without boost. I don't know how you figure a 302 is more streetable because they make less torque and like to rev more.
Old 09-22-2003, 08:12 PM
thx for replys. i actually plan to drop it into a ranger (go figure). i should post it in the ranger forums, but only about 1/4 of the peopl intrested in racing, plus, stang owners know more about their engines...
anyways, i have another question. i really thinking bout the a 302 engine swap, but i was wondering how should i go about this? i was thinking about getting the engine and all the elecrical things i need to hook up ecu@ a salvage yard, rebuild and order a 5.0L conversion kit. how much do yall think that would cost, concidering i cant rebuild or install the engine.
please dont move my post, i think i can get more information in this forum than in the ranger forum. thx for help.
Old 09-29-2003, 09:56 PM
90Stangjc 90Stangjc is offline
Dude, i dont know what year your ranger is (i might have missed that part). But if it is an older truck (90-93), it will be easier and cheaper to install the 302 in an older ranger. When you put the 8 into a newer ranger you run into space problems alot more than the older models. But either way you will have to pay a good amount of money to do the swap. By the way dont think that the ranger will automatically run 12's b/c the stock 302's are over-rated, (i have one, notice the screen name). So it's not worth your money if you just put a stock 302 motor into your ranger (plus it's a truck, which you run into tire spin with trucks, especialy with 300 ft.lbs of torque.) You'll probably end up spending more than 2,000 dollars w/ the swap.
Old 09-29-2003, 10:56 PM
calm down. i dont own any car or truck im 17 as of 9/30 and i wont get my drivers licence till 12/7 (2 mths 2 go). i wanted a fox body stang, but mom said its not gonna happen . i cant get full sized truck/F150 so 2nd best thing would be the ranger. i did my research, but i just trying to get info and opinion from stang site b/c 50%+ of the people here have 5.0L+. it would be fesable for me to get 14s or better on the track- hardtop bed cover would help out alot- weight on wheels, no air resistance. plus, engine is about 100 lbs more than 4.0L (iron vs alumium).
i dont know what year ranger(going 'shoping' 11/7 ) it will be, but i know that a 5.0L can be dropped into any ranger. what proof? the explorer, based on the ranger frame, has a 5.0 in it.
bottom line: 5.0/5.8L + superchager= a truck tha could destroy any STOCK GT( im NOT knocking the GT), and might even hang w/ a cobra, if the frame doesnt twist on me...
o well, i need to stop rambling...
Old 09-30-2003, 12:47 AM
Los Los is offline
Send a message via AIM to Los Send a message via MSN to Los
Re: 302 vs 351
no replacement for displacement.
Los
Texas Racing Scene.com
Lawton Racing
Old 09-30-2003, 04:06 AM
[SS]Disabled's Avatar
[SS]Disabled [SS]Disabled is offline
Re: 302 vs 351
Dont try and do an engine swap!!! You said a truck with a supercharger can doa GT. WHat about a supercharged GT against your truck? Besides noone usually races agains supercharged cars. So stop looking for a truck and concentrate on convincing your mom to allow you get a fox body!
BTW im turning 18 in 7 days and MY mom said that it would be stupid if a get a NON-sports car. Thats the fun of being a teenager.(She was a bit against a Mustang though Women.) So i found my honey, 1993 5.0L GT Stock.
I hope i convinced you.
A Z, a Camaro or a Stang? We'll see.
#1 The Camaro is out, it can't handle the heat of this country.
#2 So much for "The Camaro is out...", I found one which is tuned to handle the heat and its 1995 for 2.5K, its not my final decision though.
#3 Camaro is out, someone bought it before me.
#4 Found a 300ZX 1986 in good condition for 2400, will take it for a check up on thursday.
Old 09-30-2003, 08:31 PM
Yeah, listen to [SS]Disabled, (by the way i'm calm). Your 17!!! Your not going to have the money for all this anyway. But whatever floats your boat. And yes, i'm still calm.
Old 10-01-2003, 07:39 PM
rerun rerun is offline
uh dude.. ur gonna listen to your mom? i don't even have my license and i gota 67 coupe, u think my mom wanted me to get that? hell no. the think is do what u want.. if u want a f-body, get an f-body.. if u want to do the engine change, do it. but just don't screw up
Old 10-04-2003, 09:19 AM
mdh2087 mdh2087 is offline
Exactly! I don't have a liscence and my parents didn't even want me to get a cheap suv but i worked on it a bit (doing extra work around the house that sorta thing) and now i am an owner of a 95' gt. Bottom line: GET THE MUSTANG NOT THE RANGER!
302/351 weights... Steven_Folchi Performance 1 07-25-2007 12:41 AM
Heads for 302/351 Ford bcritical General Discussion 0 05-13-2005 08:20 AM
85 E-150 302 to 351 engine swap? Clayt Econoline 7 11-14-2003 04:23 PM
'85 tbird 302-351 swap TheMystress Thunderbird 1 10-15-2002 04:41 PM
302 vs 351 Kuwait TT Mustang Talk 3 01-03-2002 02:17 PM
