get an aggressive cam?
Is there anything I should replace or upgrade when i get a new cam w/ a rough idle? For a 1988 Mustang 5.0. What performance cams do you guys have good experiance with?
a police chase....that would be a rush..... |
well if u have a lot of miles on it, or gonna have to change the lifters too (the cam and the liftersd wear into each other over time, leaving the lifter with out its "dome" on the buttom)
Do you plan on just getting a cam? Because without a good set of heads to compliment the cam, you won't see more then a couple hp with just a cam.
Now your 88 is speed density. Speed density cars most of the time don't react well with a hairy cam shaft profile, or other major mods. It can be done, but you have to know exactly what your doing, and converting to MAF would help too.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
what years arent speed density, will my 88 handle any forced induction then? if not i just got another bad deal.
Speed Denisty cars can have cams swaps but you need to talk to some1 who really knows about it to pick the right cam out for you. Speed Density works n Manifold Pressure instead of Barometric Pressure. Making them more finicky about cam swaps.
Now along with the cam you should get new springs to match the cam, roller rockers, new timing chain.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
they do make a mass air conversion kit for 87 and 88 sd stangs if u were interested, i would recommend it!
Anything 89 on will have a mass air sensor
If it ain't broke it should be! |
I just put a E-303 cam in a 82 Gt mustang, it has good idle, and great take off. If you get a rough idling cam make sure you have a torque converter, unless its a manual. If you want just regular street driven power a lower duration and lift is best, if you want a street/strip car, and want that high rpm power then it's best to go with a .520 lift intake and exhaust. You can order good cams from Summit racing. Keep in mind if you do get a high lift cam make sure you dont have aftermarket rocker arms b/c 1.7:1 rocker arms create .030 more lift on the cam. But yes also switch to the mass air considering speed density sucks.
Speed Density sucks? SD cars in a stock to lightly modified have a decided advantage over MAF cars. Hence why SD is banned in NMRA stock classes.
Re: get an aggressive cam?
