Old 09-13-2003, 10:11 PM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
jdm sohc vtec ecu
aight im gettin the jdm soch vtec next week and im confussed of which
ecu to get. i was told to get the ls obdo ecu cause the rev limiter is high, but i was also thinkin about gettin the 95 civic si ecu since its vtec equipped.
help me out if u have a little more knowledge
Y LOOK FAST WHEN YOUR NOT?????????
Old 09-14-2003, 11:17 AM
91civicDXdude's Avatar
the LS OBD0 ECU (PR4) is not the one to get. It has a 6800 rpm rev limit, and will bog the car down becuase it will run so rich. Use a pm6 ECU or a PG7 1g Integra ECU and some way to activate VTEC. The PG7 will still run rich at idle, but it will give you a little better fuel when vtec kicks in.
pm6=7200
pg7=7500
pr4 OBD0=6800
And Btw, recently, i've been working with a friend of mine on reverse engineering honda OBD0 ECUs to make custom ROMS, and one thing that he's found is that the ACTUAL on chip rev limit of the pm6 is 7414 rpm.. this is whats hard coded into the actual EPROM itself. Now, the PG7 has a different kind of ROM, its internal in the microprocessor, so we really cant determine the actual rev limit of this ECU, but i know from experience that its higher thana pm6, so maybe its around 7800 or so. Oh, and oly the 90-91 PM6 and 90-91 PR4 is chippable.. the 88-89 PM6 is identical to the early PG7 ECU. We havent had the chance to reverse engineer a pr4, but its "on paper" rev limit is 6800.
***EDIT****
WOW IS YOUR EXHAUST REALLY 4.5"
Old 09-14-2003, 01:39 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
So the PM6 ecu (Si ecu, right?) rev limiter is at 7414? I believe it considering I've seen that the rev limiter on paper is at 7200 and when my car is warm i can get my car up to almost 7500 at times, probably actually around 7414. Some people said that my tach is probably just off but now I know im not crazy, lol.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 06-24-2004, 10:37 PM
JDMrexBoi's Avatar
JDMrexBoi JDMrexBoi is offline
Banned
Re: jdm sohc vtec ecu
Man i get my dualport up to 7,500 so whut are talkin bout!
Old 06-24-2004, 10:49 PM
Re: Re: jdm sohc vtec ecu
your tachometer is off. you are only revving to about 6800
Old 06-24-2004, 11:09 PM
travagliante's Avatar
travagliante travagliante is offline
Yeah right i can get it up to 7K tops, but i dont like to do that ever.
Besides why do you even need a higher rev limiter when the engine doesnt make power that high.
Old 07-01-2004, 03:45 PM
JDMrexBoi's Avatar
Banned
of course not i just wana blow my motor i put a pwo ecu and it was boggin out and shit so i just took up all the way damn that was funny the shit was spitten black smoke, but it was just for shits and giggles
Jdm Sohc Zc Vtec!!!! talonpunk831 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 02-05-2006 03:44 AM
D15b sohc vtec jdm swap jmannizzy '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-26-2005 11:30 AM
jdm d15b sohc vtec 4g4d_getone Engineering/ Technical 6 11-13-2003 07:02 PM
92-95 jdm sohc vtec 4g4d_getone '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 11-13-2003 06:11 PM
