Old 09-13-2003, 08:34 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
now i really need help bad!
I got the engine running great with a new tb gasket and a refilled radiator. But there is alot of oil dripping from behind my engine, its so much oil there it burns on the exhaust and make alot of smoke. i was thinking it might be the trannt fluid leaking out. But if i blew some kinda freeze plug or some kinda plug would there be oil shoting from the back of the engine
Old 09-13-2003, 08:43 PM
rerun rerun is offline
if u blew a freez plus u would get coolent draining fromt he engine like an elephant taking a piss on a mouse..
is your oil pan gasket good?
Old 09-13-2003, 08:58 PM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Could be valve cover gaskets, intake gasket, or any number of other things. Get underneath the car and see if you can determine the source or at least the area its coming from.
Old 09-14-2003, 01:04 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Since you changed your intake I'm going to guess it is the intake to block seal in the back of the motor. Did you use the rubber seals or RTV?
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 09-14-2003, 06:44 PM
I traced the oil leak, its coming from the top of the bellhousing, in the back of the engine bay cant see in to the to cleary to determine what it is, Does oil flow through the bellhousing at all ,, I made a new x pipe today from tubing going to install it now the car runs fine but it drips oil
Old 09-14-2003, 07:32 PM
nice welding man.. lol...
and no oil does no flow through th bellhousing.. could it possibly be tranny fluid leaking out from the torque converter (if u have an auto)
Old 09-14-2003, 08:40 PM
no i dont have a auto i dont know were the hell its coming from. Its really bugging me out.
Old 09-14-2003, 08:48 PM
Old 09-15-2003, 01:16 AM
GTStang's Avatar
Stang Guy
Re: now i really need help bad!
Maybe you need to look at my last post agian.... Cause I bet that is where the oil is coming from. That spot i mentioned is located right next to the top of the bellhousing!
Old 09-15-2003, 06:40 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Have you checked to see if the PCV is seated properly in the back of the lower intake?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 09-20-2003, 04:22 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
oil leak
hey, my truck does the EXACT SAME THING! It's probably your back gasket on your intake, take the manfold off again and use ultra black silicone in front and back. cork gaskets just suck!!!!
Old 09-30-2003, 08:13 PM
90Stangjc 90Stangjc is offline
It's probably the main seal. Your gonna have to pull the transmission and look.
Old 10-02-2003, 06:40 PM
The rear main seal, that is.
