Old 09-12-2003, 08:22 PM
jackacc's Avatar
jackacc jackacc is offline
Motor wiring harness...which one??
91 STD -> Y8 swap -> converting to OBD1
I just bought the dist. from a 93 ex but I need the wiring harness for the motor. (I have the one from the ecu)
I need to know which motor harness will work. I was told that a DX harness can be modified to make it work.
But is there an easier way with this swap? Maybe the harness from the 93? or the 97? (motor is a 97 ex)
What will work and what is the easiest? Thanks!
Jack
Old 09-12-2003, 09:10 PM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
easiest way IMO, 88-91 crx/civic si harness......just have to repin the ecu clip....alot easier than installin the obd harness.
so whats wrong with a d15b2 again?
Old 09-13-2003, 09:16 AM
jackacc's Avatar
anyone else have any thoughts today?
Old 09-13-2003, 09:48 AM
91civicDXdude's Avatar
repin the ecu plugs, change the distributor plugs, change the o2 sensor plug, and fuel injector plugs.
Old 09-13-2003, 11:35 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i want to know why you keep talking about getting a 92-95 harness? the whole point of the obd0 to obd1 harness is so you plug 1 side into the p28 ecu and the other side into your stock harness. this is what it should look like...
8 wires have tape on them. they are the ones to be extended. 4 go to the 4 wire o2 sensor, 1 is for check engine light, 1 is for knock sensor, 1 to vtec, and the last i forget. and thats it. no 92-95 stock harness needed. you would need that if you didn't have the obd0 to obd1 harness and you wanted to rewire 50 wires. which is no fun i hear.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-13-2003, 11:47 AM
jackacc's Avatar
Oh, Ok I see now! For some reason I thought I needed to use the stock harness from another motor to make it easier.
But I was still questioning if there was a major difference between the STD and DX harnesses?
Old 09-13-2003, 12:04 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
No, i dont think there is any difference between the STD and DX harnesses
KoRnSaQ
Speaker Wire Color - Which One Is Positive? imnprsd Blazer 9 08-05-2012 03:43 PM
'09 Sante Fe SE Towing -- Wiring Harness MattInTally MY 07+ 1 12-25-2010 05:49 PM
wiring harness dougb2 Venture 1 11-06-2009 08:10 PM
2000 rear door control box window motor wiring tylerk9 Deville 2 07-18-2009 10:10 AM
'96 Speaker wire colors, which ones r which? dyaballikl Mystique 0 03-11-2005 05:34 PM
