Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 09-12-2003, 08:12 PM
hccfrank20 hccfrank20 is offline
Send a message via AIM to hccfrank20 Send a message via Yahoo to hccfrank20
MY projectors are messed up, can I get some help?
Ok, well first off these projectors I have have never been any good, they are shit, i have a 96 accord and I got the plain 2 light projectors about 2 years ago, one of the lights are always burning out in a month or two, well now both are out but the bulbs arent burnt out... is this corrosion or something else? Also if it is corrosion is there a way to get rid of it and if so where is the corrosion, these projectors have me thrown because I dont know where the corroision could stem from. Thanks for the help
Old 09-13-2003, 10:20 AM
98-integra 98-integra is offline
where is this corroison is it on the inside of the headlight housing or is it on the headlight plug?? if there is corroison there has to be water getting in somewhere. have you tryed replace both bulbs i see you said they both are out and they arent burnt how do you know did you replace them to check. as for the one that keeps going out try checking the wires there could be something going to ground. sometimes if its just a little bit it wouldnt blow any fuses but it will after a while burn out the bulb. also i would check the fuses to see if thats why both are out now hope this helps
Old 09-13-2003, 10:34 AM
esp's Avatar
esp esp is offline
Send a message via AIM to esp Send a message via MSN to esp Send a message via Yahoo to esp
if u are using high wattage bulbs, u could have screwed up the wires, also the connection might be bad. also my friend has a 2001 civic and thought he had a bad connection and his low beams never worked, turned out to be that the actual lever in the steering column was broken. so there are many possiblities no it is hard to say what it could be without seeing some pics or looking at it in person
*RIP* Integr8 aka Ryan *RIP*
5/29/03
www.fotki.com/esp
THIS OG IS GONE retired for good. peace yall. create a crew for me
Hope I can get some help... kellbell Intrigue 12 07-26-2007 09:01 PM
88 camry messed up can YOU help?? JacksonJessop Camry/Camry Hybrid/Vista 2 01-14-2006 08:11 AM
I'm new to this Mitsubishi game can I get some help!! Wes Moran Lancer 6 01-21-2003 09:24 AM
can i get some help for a sec..... richard simmons 3000GT/Stealth 3 09-10-2002 09:51 AM
Can I get some help from the pro's plz, Ime building my car and need help! Matthew111 Engineering/ Technical 1 07-28-2002 09:23 PM
