Old 09-10-2003, 06:17 AM
tylercrx tylercrx is offline
Question dirty oil and emissions
within a month of a fresh oil change and oil filter change, my oil gets black, and i see a bunch of emissions from my side view mirror. a whole bunch of whitish smoke comes out, primarily when i change lower gears. i dont know if these two problems are related, but maybe thats where one of you could help me out. i am running a d16a6 with always 89 octane fuel here in hawaii (2 bucks a gallon ) i know that i am running rich, maybe this can account for one of these problems or even both. any help would be greatly appreciated.
Old 09-11-2003, 12:16 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
maybe they didn't do regular oil changes. try changing until it becomes clean.
have you tried adding engine lubricant?
also what kind of motor oil are you using?
Old 09-11-2003, 02:11 PM
Arrow
no i havent tried using engine lubricant, and i am using 10w30. i just bought a new oil filter and 4 liters of 5w40 oil. my car has 110000 miles on it. thanks for your help.
Old 09-11-2003, 08:11 PM
rubix777's Avatar
try thicker oil because it might be leaking through and being burned with the fuel.
Old 09-11-2003, 10:05 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Buy an engine compression tester. They're very cheap, and definitly worth the preventive maintenance. It's just a little gauge with a hose on it.
You unplug your spark plugs, screw this thing in, have a friend turn the key to start the car (it won't start it though, it will just turn over because the plugs are out) and look for the one cylinder (or more) showing a drastically different pressure reading than the other ones. On your car it should read 176 +-10. If one is like 140-150 then you have a fried piston ring and oil is seeping up into the combustion chamber, burning with the fuel, and blowing smoke out the back. New rings aren't cheap, but you could buy a junkyard engine in great condition for about $150
Dirty oil after 900 miles caffeineaholic Caprice 16 12-13-2010 10:56 PM
Windstar dirty coolant...oil and ABS light on...Help windstar_novice Windstar 5 11-12-2005 07:18 AM
Dirty Oil rruddfan21 Metro 1 10-02-2005 12:51 PM
Does dirty oil bring down mpg? Koojo Maintenance 5 06-22-2001 05:58 PM
