Old 09-09-2003, 06:21 PM
DeJa_Voo DeJa_Voo is offline
intake question
I have a 99 eclipse gst and want to get injen intake but they ask for a stock bov or aftermarket bov. I have stock but want to eventually put an aftermarket in so which should i purchase? If i get the intake w/ stock bov am i going to have to buy additional parts in the future when i get the aftermarket bov? Is there a difference between the two?
Old 09-10-2003, 12:53 AM
kjewer1 kjewer1 is offline
AF - Advisor
I'm going to try to answer this question even though I have never once looked up an injec intake, so take it with caution I'm going to ASSUME that they are assuming an "aftermarket" BOV is going to vent to atmosphere. In which case the return tube will be deleted. I can see no other reason for them to ask this question. If this is the case (and its up to you to find out for sure ) then all you'll have to do when you upgrade to a BOV that vents to atmosphere (make sure you know what youre getting yourself into there) you just have to cap off that return tube that will no longer be used.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-10-2003, 02:56 AM
zer0bot's Avatar
zer0bot zer0bot is offline
Re: intake question
very interesting, i have never heard this. i was wondering if someone with an intake could shed some light on the question. as for venting to the atmoshere 95 GSXracer is right make sure you know what you are getting into because you will run VERY rich( as in air to fuel ratio) inbetween shifts if you vent to the atmosphere. some people have problems when they do it, some don't. most will say " get a 1g blow off value instead of an aftermarket one. the 1g should hold anywhere from 18 - 20 psi uncrushed, i have heard of 25 psi uncrushed but only once and online so who knows if it was true. just my
zer0 s:
"It's like playing rock, paper, scissors and sucker punch to the throat. The sucker punch always wins."
Old 09-10-2003, 10:38 AM
well does the intake w/ aftermarket bov come with a bov fitting? I might as well just buy the aftermarket one then cover the inlet w/ a rubber cap or something
Old 09-11-2003, 12:13 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
k to answer the question, you want the one for the stock bov, even if you're goin upgrade later, SO GET THE ONE FOR THE STOCK BOV.
also check out www.dejontool.com
they dont have the "bling" as the injen does, but its cheaper and work just a good or maybe better
-Agim
Old 09-11-2003, 10:18 AM
turboawdgsx turboawdgsx is offline
Re: intake question
FourG63 couldn't have said it better. I prefer the Dejon parts over pretty much anyone. They've got a great selection, as well as any color/combo choice anywhere.
Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?"
Old 09-11-2003, 10:22 AM
Four G63 why should i get the one w/ stock bov? Everyone is saying something different but wont it be harder later if i try to upgrade to aftermarket bov w/ the stock settings on the intake. The intake at optauto.com is the one im trying to get. If i do get new bov which is a good choice 1g, greddy S, HKS? then dont i need a ic pipe
Old 09-11-2003, 04:37 PM
AF - Advisor
I usually suggest a 1g, crushed to 18 in/hg. It will hold you over until the point that you have to upgrade to a real BOV, should you ever take it that far. Real BOVs are those like Tial and SARD. Good to over 30 psi. Not the bling blang shyte valves, but they have thier place.
Kevin Jewer
Old 09-11-2003, 05:30 PM
Japmetal
Guest
Posts: n/a
Re: intake question
If the people who've offered you advice are right about the recirc/venting BOV difference, it'll be MUCH harder to adapt an aftermarket BOV item to take the recirc valve than it would to block up the extra tube on the recirc intake when you upgrade the BOV.
Old 09-12-2003, 02:13 AM
Re: intake question
Because you NEED the recirculation tube
-Agim
intake question Darkwing '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 42 11-02-2001 11:57 PM
Intake Questions 2K1 G20 Engine 13 10-09-2001 03:35 AM
ebay intake question greekman Engine 4 08-07-2001 08:42 AM
Intake question? DVSNCYNIKL Accord/TSX/Accord Hybrid 3 08-01-2001 10:20 PM
air intake question SkylinesKillAll Engine 18 04-27-2001 09:51 AM
