Old 09-08-2003, 10:01 AM
doug294 doug294 is offline
Send a message via AIM to doug294
Exclamation Car went wack, need help!
Ok heres what happened. I went to the car wash, then filled up the tank, then got on the highway. Well I got going for about 10 miles and all of a sudden I hear put put boom! Look up and see a puff of black smoke come out my tail pipe. Well I try giving it gas with no response so I take it out of gear and coast to the side of the raod. I tried to restart it and all it did is like put put pop, put put pop. Well I called my dad and he comes and I try it again. Well I get it started and it was running rough as crap. When I floor it it just revs to like 1-1.5k and back fires like crazy. We think it is either the fuel pump or jumped timing, what do you guys think?
Old 09-08-2003, 10:38 AM
91civicDXdude's Avatar
could've gotten the distributor wet ... take the cap off and check things out. when it doesnt rev its a timing/distributor issue.
Old 09-08-2003, 10:40 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Maybe timing, but I doubt fuel pump. The fuel pump constantly puts out a certain pressure, no matter what rpm the engine is doing. (The line that doesn't go to the engine from the fuel filter is the return line, which takes the extra gas back to the tank). The fact of it back firing also makes me think that something else, more serious, is wrong.
That sucks about your car though, I had a Honda where a $2 crank oil seal leaked onto the timing belt (oil eats belts) and the belt broke causing over 200 in damage because there is no valve clearance..It's like getting a swift kick in the nuts.
Old 09-08-2003, 10:54 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
FROM PERSONAL EXPERIENCE.....i think itz the distributor....
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-08-2003, 05:09 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
It's possible the timing belt could have skipped a tooth.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 09-08-2003, 07:50 PM
Well the guy called and said my spark plugs were about shot and something in the distributor was stripped. Cost $132, oh well, gotta have a car.
Old 09-08-2003, 09:45 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
CHECK UR ROTOR FIRST!!!!!
This is what happened to my car last week! i didnt know wtf was going on, the car wouldnt rev past 2 - 2.5k and ran like a bag of shit, i couldnt get it goin ne faster then 60km/h in 5th, sounds like u got the same prob i did, take off the distributor cap, then look and see if that screws in the rotor, if its not, then theres ur problem dude!
Good Luck
Not sure which car to pick, need help No_LiMiT Car Buying Q&A 0 02-15-2009 09:23 AM
All brake lights went out! Need help. blueaccord19 Prelude 0 06-12-2007 06:47 PM
1996 Winstar GL - Alarm Went Off - Need Help mdirfan Windstar 0 04-06-2004 04:42 PM
Car just quit,need help! operationyak S-10 3 11-11-2002 10:28 PM
