Old 09-08-2003, 02:56 AM
S|L3NoZ S|L3NoZ is offline
Send a message via MSN to S|L3NoZ
Question Turbo LS/VTEC.....
I'd like to know what's the best head for a Turbo LS/VTEC??? Should I go with Si-R, GS-R, Type-R, etc And plz explain why.....From now on, I've been told to put a Si-R head, but I wanted be sure before doing something.....I'd like to understand what each of these heads do to make my choice regarding my needs. Thx a lot for your help
Old 09-08-2003, 03:37 AM
S13GTR S13GTR is offline
b16 head would be best in my opinion. It has the most desirable combustion chamber and for the money you would spend on a type R head you can get all the headwork done and it will outflow a type R head any day of the week. Plus I do headwork.
Hint
Hint
Old 09-08-2003, 05:47 PM
boosted331 boosted331 is offline
Re: Turbo LS/VTEC.....
Hint
Hint
psst guess what, B16 heads and ITR heads come out of the exact same casting, and ITR heads flow a tiny bit more stock because they're cleaned up @ the factory. Remind me to never buy anything from you ever
Old 09-08-2003, 06:43 PM
Re: Re: Turbo LS/VTEC.....
No shit. sounds like your on the rag because I dindnt feel like typing when I was falling asleep.
FYI: b16 and b18c5 have the same heads but the type r flows better because it has bigger machined bowls by the valve guides and narrow valve necks on the intake side. GSR heads have a totaly different setup with a square combustion chamber for improved midrange and torque. Going ls vtec you would have slightly higher compression using the gsr head but the b16 and type r's round combustion chamber is better for top end motors. You get a faster burn with a round combustion chamber and longer burn with square chamber (just slightly).
I got some questions. When you talk about a valve angle job, this is part of the head right!?!? Coz I wanna do a 5 angles valve job on it. And I want to know with this job done on the head, what would be the best choice????
Turbo LS/VTEC hp gain? DeleriouS N2O | Turbo | Superchargers 13 10-02-2004 08:14 AM
Turbo LS/VTEC hp gain? DeleriouS JDM Motor & Parts info/chat 2 09-11-2004 07:12 PM
twin turbo ls/vtec eclipse2quick21 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 15 06-03-2004 03:19 PM
LS with turbo, or LS with LS/VTEC and Turbo IntegRocket32 Integra 3 10-11-2002 02:13 AM
