Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-07-2003, 12:52 PM
BLottman BLottman is offline
Question Timing Belt Replacement 87 Prelude 1.8L
I need some help lining up the Crank and Camshaft sprockets on this 1.8 L engine.
The upper camshaft pulley has a some spokes and one of the spokes contains the word "Up" stamped on it. The crankshaft gear has a countersinked punch on it. Which direction should both marks be aligned when I place the timing belt back on it.
Apparently there are some marks on the timing belt covers but and I'm not sure how all marks should be aligned.
I also have the rocker arm cover removed and can see when the valves are all closed, intakes open, and/or exhaust valves opened when I rotate the camshaft pulley. I can tell when the number one cylinder is also at TDC as well. Is there a picture/diagram/instructions or advice that someone has that can assist me?
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
