Old 09-07-2003, 12:06 PM
Sennake's Avatar
Sennake Sennake is offline
In-progress : Ford Focus WRC 02 (Tamiya 1/24)
The "battle" finally started : this is a very early stage of the paintjob of the bodywork. I applied a coat of primer and 1 coat of "performance blue". It doesn't "cover" very well so I guess I'll have to add at least 2 or 3 more layers. More pics and tips later...
* WWW.SENNAKE.BE *
Old 09-07-2003, 12:09 PM
potsie potsie is offline
Looks good so far. How much time are you going to spend making it accurate - correct wheels, vents etc. Or are you simply building OOB? I'd be interested to see you give it the full treatment - knowing your skills it would look great.
Old 09-07-2003, 12:24 PM
Sennake's Avatar
I'm gonna build about a month I guess. I'm not changing anything, but I'll detail everything as good as possible. I'm also going to give a lot of attention to the driver and co-driver.
BTW : the wheels don't need to be replaced, Duval-Fortin raced the Focus in Corsica with these wheels (see picture).
* WWW.SENNAKE.BE *
Old 09-07-2003, 02:20 PM
Guido Guido is offline
Interesting report! from yet another Belgian rally driver!
Old 09-07-2003, 04:26 PM
Midnight Racer's Avatar
Can't wait to see more progress.
Old 09-08-2003, 06:21 AM
RallyRaider's Avatar
Zomby Woof
Another masterpiece in the making for sure. How do you build them so quick Sennake? I'm envious!
What paint are you using there? doesn't like the corners much does it Lots of very fine coats might do the trick.
Main mods needed to the kit are the roll cage (remove the horizontal bar behind the seats) and the headlights (much harder to fix). Dash is a bit different too but hardly noticeable. The rest of it is accurate for Duval's Tour de Corse car as far as I can recall.
Old 09-08-2003, 08:50 AM
OPM's Avatar
OPM OPM is offline
Send a message via ICQ to OPM
you dfinately need to fix the headlights,haven't seen a focus from tamiya build up with correct headlights for 2002 till today...so you have the chance to do it
Old 09-08-2003, 03:17 PM
Sennake's Avatar
Re: In-progress : Ford Focus WRC 02 (Tamiya 1/24)
I try to work on my models a few hours a day (2 or 3 hours after work). Of course I don't always succeed
I'm using the Tamiya TS-51 spray cans. I applied a second coat today and it looks a lot better, although a third coat will at least be nessecairy...
The roll cage : no problem, will certainly remove the horizontal bar. The headlights : dunno, trying to fix them might actually make them look worse than without changing anything... Are there any aftermarket ones? Oh well, myabe I get a brilliant idea one of these days
* WWW.SENNAKE.BE *
Old 09-09-2003, 03:53 AM
Sennake's Avatar
@ RallyRaider : thanks for the "horizontal bar tip", but I suppose you have pictures of a Focus interior to prove your point? Not that I don't believe you, but could you maybe spare me a few of these pics please? Could come in handy when I start detailling the interior
Thanks in advance!
* WWW.SENNAKE.BE *
Old 09-09-2003, 04:00 AM
chipanggo's Avatar
chipanggo chipanggo is offline
looking good. awesome paint job. can't wait to see more.
Old 09-09-2003, 10:36 AM
Sennake's Avatar
After 1 coat of primer and 3 coats of TS-51, I'm finally pleased with the result I'm gonna stop spraying now, and I'll start thinking of how to solve the headlight-problem. As a matter of fact, I think I know a possible solution : what I need are the "mirrors" of 4 separate lights, so I can "transplant" them into the Focus' headlight-block. And I think I'll use the ones I saw in one of my Ford Escort RS Cosworth boxes (of which I have 4 in my stockpile)... The spotlights that are to be put on top of the hood might do the trick...
* WWW.SENNAKE.BE *
Old 09-09-2003, 10:46 AM
slk320 slk320 is offline
AF Premium User
Send a message via AIM to slk320
Very NIce paint!! Its my favorite from Tamiya line!!
Old 09-09-2003, 11:07 AM
The Lambrusco Kid's Avatar
The Lambrusco Kid The Lambrusco Kid is offline
AF Premium User
What's wrong with the headlights exactly? I've got the hasegawa 99 safari version, does it have the same mistake?
__________________________
"Back off man, I'm a scientist."
Click banner to view thread
Old 09-09-2003, 11:21 AM
ales's Avatar
ales ales is offline
Forza Schumacher
No, that one is correct if you're building the 1999 version. The headlights were changed during the 2001 season. Look at some reference photos - it's quite easy to see the difference.
Old 09-09-2003, 01:22 PM
freakray freakray is offline
AF Modelrater
Re: Re: In-progress : Ford Focus WRC 02 (Tamiya 1/24)
Look at the box art on the 2002 Focus and the mistake is quite evident.
AF User Guidelines
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
