Old 09-06-2003, 09:30 PM
7string 7string is offline
96 Taurus radiator fan will not shut off
Here is the deal:
Fans stay on constantly even when turning the ignition off. Until the battery is drained. No other problems that are evident, no trouble code, no check engine light or other warning lights. I replaced the coolant sensor and reset the computer.
Still happening...
There must be a cooling fan relay or sensor, or coolant temperature switch that controls these fans. I can not find one in any of the parts stores online or otherwise.
Help if you can, this is driving me nuts.
Old 10-03-2003, 08:31 PM
mikeo550 mikeo550 is offline
that would be your sensors... heat sensors.. i think theres 3 or 4 of them.. and your thermostat.. plus it wouldnt help to re program the computer
Old 10-06-2003, 07:17 PM
MunsterGarage MunsterGarage is offline
not sure..but might be a relay in the radiator....temp raises...kicks the fan on...cools down..shuts it off.....just a thought
Old 02-02-2004, 02:07 PM
knguyen5 knguyen5 is offline
Re: 96 Taurus radiator fan will not shut off
I have a Taurus 96 too. And have exactly the problem with the radiator cooling fan running on and on. has Anyone fixed this? please help.
Old 10-16-2008, 05:29 PM
diofan diofan is offline
Check your CCRM Located next to the battery.
Make sure the connection is snug and maybe give it a tap with the handle end of a screwdriver...worked on my 96 sable.
Radiator fan will not shut off pontoonman Windstar 1 02-16-2010 12:01 PM
1999 Cherokee Engine Fan will not shut off Kent L. Nelson Grand Cherokee | Grand Cherokee SRT8 5 03-09-2007 03:44 AM
AC blower fan will not shut off... ghink LeSabre 6 08-18-2006 03:24 AM
My cooling fan will not shut off after driving. Any Ideas? dstew42 Cabrio 2 10-15-2005 11:35 AM
Fan will not shut off? dpbrowne SC/SL/SW 1 04-15-2004 04:10 AM
