Old 08-14-2006, 08:21 PM
ghink ghink is offline
AC blower fan will not shut off...
Have a 1994 Buick LaSabre that the AC blower fan will not shut off. Have to pull the AC fuse to disable fan.
Any help will be apprciated.
Old 08-14-2006, 08:36 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: AC blower fan will not shut off...
I assume that you have auto climate control, if so, you need to replace the blower control module. Cost about 100 bucks new at Advanced, or you may find one in a bone yard for half that.
Old 08-15-2006, 07:43 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
what about a stuck relay?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 08-15-2006, 09:05 AM
imidazol97 imidazol97 is offline
AF -Advisor
Do you have an automatic dual control air conditioner with the temperature readout screen? If so, the blower control relay that's on top of the box under the hood close to the blower motor is probably the place to start checking. It's hidden under the maxifuse relay box, which can be moved up after taking out a couple of screws to make room to get at the blower control relay, which is really a circuit board that controls the blower.
Old 08-16-2006, 02:30 PM
I do have automatic dual control air conditioner with the temperature readout screen but can't find blower control relay/circuit board that controls the blower.
Old 08-16-2006, 04:24 PM
Found it!
Old 08-18-2006, 03:24 AM
Installed a new AC blower control module and that fixed it.
Thanks to all that replied.
