Old 09-06-2003, 06:54 PM
mfmark5007 mfmark5007 is offline
Hondata and Turbos
I heard many people tell me that I had to upgrade my Fuel system (by upgrading a ECU) if i wanted to maximize my TURBO.
Is that true?
Do i really have to upgrade anything?
What if I bought a HONDATA....would that replace the necessary modifications?
Old 09-06-2003, 07:49 PM
boosted331 boosted331 is offline
Re: Hondata and Turbos
Is that true?
If you want to run a turbo on your car, you should upgrade your FUEL system, ie: new pump(s), lines, filter, rails, injectors, etc, etc. An ECU upgrade has nothing to do with your fuel system, other than controling fuel pressure and when the injectors pulse. If you ran a turbo on your car without touching anything in the fuel system or ECU the motor would grenade, no ifs ands or buts. Hondata is a piggy-back system for the stock honda ECU's which lets you change fuel and timing tables, boost, rev limits, etc.
Difference in Non Turbo and Turbo Clutches? Cbreda1985 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 11-20-2004 07:49 PM
non turbo and turbo EPROM ecu guys enter in... 95eclipse-gsx Off-Topic 2 06-25-2004 08:30 PM
hondata and my warranty bobmarley4546 Integra 2 05-19-2004 03:07 PM
hondata and short ram iptaycat Integra 3 04-22-2004 06:00 PM
LS with turbo, or LS with LS/VTEC and Turbo IntegRocket32 Integra 3 10-11-2002 01:13 AM
