Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-06-2003, 05:46 PM
free1776 free1776 is offline
Unhappy Manual gearbox problem
My wife has a 95 SL with a 5-speed manual. on Thursday, she called me and said it wouldn't go into 2, 4, or Reverse. I can't seem to find the haynes repair manual (not that it was worth a hill of beans anyway). I put the car up on jackstands today to check things out, but it looks like the gear changes are executed by two cables which run into the gearbox. Before I go through the hassle of pulling things apart, can someone point me in the right direction? I can't even see where to add gear oil. If I have to have a shop do the work, I'm going to donate the piece of junk to charity for the write-off and buy an old toyota.
Old 09-07-2003, 09:05 PM
AkinaSpeedStar's Avatar
AkinaSpeedStar AkinaSpeedStar is offline
Tofu Drift Crew
Send a message via AIM to AkinaSpeedStar Send a message via Yahoo to AkinaSpeedStar
i will take the car if you donate it
Current Rides:
2007 Kia Sportage
1992 Nissan 240sx (SR20)
1977 Chevy step side
1963 International Scout
1988 Nissan 300zx
Old 09-07-2003, 09:47 PM
Re: Manual gearbox problem
Are you a tax-deductible charity?
Old 09-08-2003, 04:18 PM
Tofu Drift Crew
I could Be
well no, but if you dont have to show proof that you gave it to one you cxould just say you did, i could use a car to work on in my auto class for transmissions, i could try to get some money saved up to, you in califronia????????????????????
Current Rides:
2007 Kia Sportage
1988 Nissan 300zx
Old 09-11-2003, 10:03 AM
Wilson_Shaw Wilson_Shaw is offline
A couple possibilities: either the bolt in front of the shifter that holds the cables in place is loose, or you could have a bad cable. First, try checking out the shift cables in front of the shifter by removing the console. When you are shifting into 2nd, 4th, and Reverse, you are pushing the cables on the passenger side through. If everything looks good at that end, check ends of the cables that connect to the shift tower on top of the transmission.
The gear oil goes into the same tube the transmission's dip-stick is in. This is located below the master cylinder. The top is red in color.
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
850i gearbox problem/Repair manual mikeholstick 8 Series 1 06-07-2004 07:31 PM
Audi launches V6 TT coupe with automated manual gearbox YellowMaranello Automotive News Desk 0 11-25-2002 05:06 PM
GTS-4 Manual gearbox magnanimous Classifieds 0 09-30-2002 09:05 PM
Theoretically, how much torque could the strongest 6-speed manual gearbox take? 454Casull Engineering/ Technical 23 09-07-2002 10:03 PM
