Old 07-24-2002, 11:49 AM
454Casull 454Casull is offline
Theoretically, how much torque could the strongest 6-speed manual gearbox take?
I'm just wondering, since some guy told me that automatics are best for dragging because manuals can't handle the power.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 07-25-2002, 09:48 AM
SaabJohan SaabJohan is offline
A manual gearbox can generally handle more torque than an automatic gearbox with the same size. The manual also have better effiency.
Old 07-25-2002, 02:28 PM
So are you saying, that if you enlarge a gearbox (and its internal components) it can handle more torque?
Old 07-25-2002, 03:00 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
yeah, you can make a gearbox to handle any amount of torque you want. The troubles start when you want to make it small, or spin it quickly.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 07-25-2002, 05:55 PM
or spin it quickly
So the larger it is, the lower the maxium RPMs?
Old 07-25-2002, 06:36 PM
not necessarily, it just gets more and more critical that you properly design the parts if they're big & fast.
Old 07-25-2002, 06:38 PM
Oh... Thanks.
Old 07-25-2002, 07:26 PM
BeEfCaKe BeEfCaKe is offline
Automatic may actually be better when you really got alota horsepower. This can be seen here (www.exvitermini.com). The drag skyline the owner of the site has put together has been put to a track, using a 6-speed Hollinger manual drag box, but due to the high power output, an automatic gearbox is now being tested for use, just as most other competitors are using.
Old 07-25-2002, 07:33 PM
Pennzoil GT-R's Avatar
Pennzoil GT-R Pennzoil GT-R is offline
theoretically a gearbox can handle any amount of power/torque. i really believe autos are best for acceleration as they can match the revs perfectly on the upshift. this is why alot of race cars now use autos.
Old 07-25-2002, 09:23 PM
What kind of races?
Old 07-25-2002, 09:26 PM
F1 use switchable semi-autos for a start, cant get much better than that.
Old 07-25-2002, 10:31 PM
They're closer to manuals than automatics...
Old 07-26-2002, 12:27 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yeah, they are sequential. There is a still a clutch, it is just controlled by the computer.
Old 07-26-2002, 03:48 AM
texan's Avatar
texan texan is offline
Writer Mod
I feel that automatic transmissions with torque convertors are more ideally suited to high powered applications than traditional manual transmissions. The reason is simple, torque convertors soften the blow engine torque delivers to the gears and clutch packs. What usually breaks in a transmission is the gear teeth, which is either caused by too much torque or too hard a shock load. Manuals naturally shock the gears more by using clutches which grab suddenly, though there are slipper clutches which soften this blow (commonly used in racing bikes). The additional advantage an auto has is in using multiple clutch packs and negating the need for inherently weak synchro mesh gears, which are often the first to fall in a high performance manual tranny.
None of this is to say that either system can't be broken, I only mean that autos naturally soften the hit from a powerful engine, spread the torque out over multiple clutch faces, and do away with brittle synchro gears. Any properly designed transmission should handle the intended torque loads, it's only when you go beyond their design that you find weak points in each system. And remember, it's not horsepower which breaks transmissions, it's torque. A tranny is rated by torque capacity, the horsepower an engine generates has nothing directly to do with whether it will break or not.
'03 Corvette Z06
'99 Prelude SH
Old 07-26-2002, 09:33 AM
There has been no mention horsepower in this thread except in yours.
