Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-06-2003, 12:13 PM
Car_Doc86 Car_Doc86 is offline
automatic to manual
great deal just came up on a 240, but the downfall is its a automatic. Anyone know about how much the transition from auto to manual might cost me? thanks a lot
Old 09-06-2003, 01:01 PM
klohiq's Avatar
klohiq klohiq is offline
if you swap it yourself it should be cheap....less than 500 if you find a decent deal on a tranny. Then you need a few cheap items like shift boot, manual gauge cluster...etc
Old 09-06-2003, 01:18 PM
jjm131 jjm131 is offline
Here's a list of the parts that you will need for a five speed swapon an S-14.
List of parts needed for 5-Speed swap:
Factory Service Manual
Manual Transmission
Shifter
Release Bearing
Pressure plate
Clutch
Flywheel from a m/t
M/T Mounting plate
Flywheel Bolts (m/t bolts are longer than a/t bolts)
Clutch pedal
Brake pedal (From M/T car)
Clutch master cylinder w/ resevoir
Clutch slave cylinder
Clutch hydraulic lines (Main line, bleeder line, rubber line to slave cylinder)
Drive shaft front & rear section
Adapter bolts & nuts for mounting crossmember to the 5 speed (2)
Reverse light sensor, Neutral position sensor, 5th gear sensor (on side of 5 speed)
Lower shift boot & plate
Upper Shift boot & Finisher plate.
To get instructions on how to do it yourself go to http://www.240sx.org/links/installs/s14_5speed_swap.htm
Old 09-06-2003, 03:51 PM
thanks tons for the info but i drove an hour to go test drive the car and guess what...its a lemon. owell search continues. let me know if you find the 240 that im lookin for
Manual vs auto yazzagaffix Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 09-15-2009 05:45 PM
AutoMatic-Manual VenomRacing Cavalier 4 10-12-2004 11:59 AM
automatic/manual tranny conversion murret-san '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-28-2004 02:52 PM
automatic manual transmision conversion? c32b1 NSX Let's get Technical! 3 02-10-2004 09:54 PM
Automatic manual. chris26969 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 10-22-2002 01:04 PM
