Old 09-05-2003, 04:18 PM
jtluvul jtluvul is offline
Question Normal Idle and Fast Idle problem
Hi,
I have a civic 89 LX with a 1.5L 16 Valve engine and a Dual-Point Fuel Injection system. I'm having problems with the Idle settings. The Idle specification for the car stated in the manual is as follows:
- Normal Idle (P or N position) 750rpm +/- 50rpm
- Fast Idle 1500rpm (about)
The way my car is performing seems like it's doing exactly the reverse as what it should be. When I turn the car on and keep the car either in Parked or Neutral, the RPMs read about 1200rpm - 1300rpm. When I change gears to R or any of the Ds (D4, D2, D1) then the rpms go down to like about 750rpm - 800rpm. I'd appreciate any suggestions of what maybe causing this and how to fix it.
Thanks in advanced.
Old 09-06-2003, 12:29 AM
BullShifter's Avatar
When the car is first started & cold it should idle that high. Wait til the engine warms up(fan comes on then off) then check your idle.
No problem found - See ya!
FAST IDLE with New IAC - 2001 E150 5.4 leroge Econoline 0 01-19-2011 04:46 PM
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
1987 Grand Marquis 5.0L FAST IDLE problem Johnobub Grand Marquis 3 10-09-2009 08:10 AM
Hard Start and fast Idle? frogdog34 Cherokee 1 09-22-2004 08:09 PM
spare TPS and fast idle control valve? bpt323 '71-'87 Civic | CRX 0 06-01-2004 12:27 PM
