Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 09-05-2003, 02:07 PM
Real GTR's Avatar
Real GTR Real GTR is offline
Send a message via AIM to Real GTR
4wd Trouble
I've had my skyline for about 3 months now and when I bought it I had Motorex put the Power FC in it.
Well about 2 months ago the check engine light and 4wd light comes on.
I thought it was the new rims I put on but that was'nt it because after a while the lights cut off.
Then the 4wd light starts cutting on a everyother day. Then for some reason over the last 2 1/2 weeks it has'nt went off at all.
So I decide to put the factory computer back in so I could pull the codes and my light hasen't came back on then.
ANy one have any insight on what could be wrong?
Old 09-05-2003, 04:42 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
What does your front torque do when you launch pretty hard?
I am just askin, but you do have all the same size tires on all 4 corners right?
There are a few sensors that play a heavy part in the 4wd system, it might be a loose wire.
Need to pull the codes, that will help. Like you mentioned.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 09-05-2003, 11:18 PM
Real GTR's Avatar
I have the same size all the way around I even put the ones that came on the car on and it still did it. I know the camber is off in the front real bad but it's been that way ever since I bought it. And if that's causing the code how cone it won't code with the stock computer in.
When the 4wd light is on no front torque at all.
I'd love to be able to pull the codes but when I put the stock computer back in everything works and no 4wd light or check engine.
The problem has to be in the Power FC unit, any ideas. I can't pull the codes out of the FC.
Old 09-06-2003, 02:26 AM
SkylineUSA's Avatar
That is a strange problem.
So, have you installed the FC again, to see if happens again?
Old 09-07-2003, 01:56 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
First which powerFC do you have and which GTR do you have? The R32,33, and 34 all use a different version of the powerFC. Also unless it is set right it may not be picking up the signals from one of the many sensors. You have a throttle position sensor, G-force sensors, and anti-lock brake sensors that the ATTESSA system all monitors in order to control how and when it works.
From what you discribe it sounds more like you have the wrong PowerFC in the car.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 09-07-2003, 03:59 PM
Real GTR's Avatar
I have a R-33 GT-R. The serial # says it's for a GTR33L. Motorex installed it and it ran good for a month.
I'm going to put it back in this weekend and see what it does I miss it. It made a hell of a differance in the way the car ran.
I'll keep you posted.
Old 09-14-2003, 06:07 PM
Real GTR's Avatar
4 wd light finaly came back on on the factory computer but no check engine light thought. So it's not the Power FC. I juggled the wires to the harness for the computer and the light went out so I'm going to have to go throught the wires and trouble shot there mess.
Old 09-17-2003, 11:54 AM
RazorGTR's Avatar
Skyline Man
it could be the plug or a wire. Either way an eletrical fault is a nightmare, at least you got lucky and narrowed the area down.
Old 10-25-2003, 07:54 PM
tyndago tyndago is offline
Send a message via AIM to tyndago
Re: 4wd Trouble
Looks just the way a Power FC should look...
Look at pin 53 on the harness . Thats the speed input to the stock computer.
About the only one that goes though the / to the Power FC.
I cant say I believe its being caused by the Power FC or harness.
There is troubleshooting for the Attesa system...
The thing is I dont know it off the top of my head .... R32's are easy... R33 you can check with a Consult unit. There is another way , but I need to dig it out...
Check the fluid level for the Attesa system in the trunk....
Sean Morris
http://www.2009gtr.com
http://www.gtrusablog.com
Old 11-04-2003, 11:45 PM
Real GTR's Avatar
I finaly put the power FC back in and no light. Checked the pins and fluid and there cool. So most likely it's in the harness it self but everythings working fine for now.
4wd trouble / 97 jimmy 4.3 97 Jimmy SLE Jimmy 2 09-19-2006 08:36 PM
4wd troubles 95xjsport Jimmy 1 04-08-2006 04:08 PM
4WD trouble on '95 Sportage sublime Sportage 9 03-07-2006 07:16 AM
4WD trouble...AGAIN dian Dever Sportage 4 06-16-2005 08:58 AM
4WD trouble..... ajfireman TrailBlazer | Trailblazer EXT 0 12-17-2003 10:34 AM
