Old 09-04-2003, 05:45 PM
haaj haaj is offline
Send a message via AIM to haaj Send a message via Yahoo to haaj
Question Which clutch?
Ive got an 88 Civic 4dr DX 1.5L, stock motor, and my clutch just burned out after about 8,000mi (4 months) so I'm about to replace it. It was replaced just before I bought it. When I go to Kragen Auto they say they have 2 diff clutch kits for my model - one is 7 1/2" one is 7 7/8". Which one should I get? Monument Auto Parts only has the 7 1/2" clutch kit.
I wonder if maybe it takes the 7 7/8" one but the last guy that had the car installed the 7 1/2" and it fit, but burned out the clutch in 4 months because of it. Of course, the clutch could have also burned out because this is my first manual-trans car... I'm also planning to do all the work myself with a buddy's help and I've never replaced a clutch before so I don't want to put on the wrong part and not know it.
Thanks in advance for any help!
Mike
Old 09-04-2003, 06:07 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
It all depends on the flywheel. The Si's and I think the EX's had the 7 7/8ths and the DX's and LX's had the 7.5's. The disc is the same for both, but the flywheel is a little bit bigger and the one for the Si's has about 30lbs more pressure. I got myself an Si Flywheel so I could get the higher pressure clutch. Of course, if you want, I have a full ACT setup on an Si flywheel that I would be willing to give up for $200, which is probably what the Kragen clutch will cost you anyway. I also have an Si tranny that I'd sell to you for $150, which will give you lower gearing and better acceleration. In any case, try to get to an Si flywheel and clutch, and check the torque that the pressure plate makes, cuz that will affect your launches.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 09-05-2003, 01:24 PM
Re: Which clutch?
4GZChatch, thanks dude you rock, that is exactly what I needed. My car is broken down right now so I'm just gonna use stock parts, but I'll try to throw the Si clutch and flywheel on there if I can get both of those parts by tomorrow - otherwise I'll go for the 7 1/2" part.
Thanks!
Mike
Old 09-16-2003, 03:27 AM
cant think cant think is offline
hey 4GZChatch, do you still have that si tranny and flywheel?
Also what is a good street performance clutch?
Old 09-16-2003, 07:20 AM
4GZChatch's Avatar
Actually, i found out that it's a ZC trans w/a stock LSD, so I've decided to use it and go Z6. Sorry. But you can Email Kris, he has a DX tranny that came out of my car in his shop, with the flywheel and an almost new clutch pressure plate. Get him $75 plus shipping and it's yours. It runs good, only grinds a little when you shift at high rpm's from 2nd to 3rd. Hope that helps. Sorry to disappoint.....
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Which clutch system is better RalphCare 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 10 07-23-2003 06:44 PM
Which clutch?? scobel Off-Topic 6 04-11-2003 01:59 PM
need to know which clutch cable civickiller '88 - '91 Civic | CRX | Wagon | Shuttlee 2 01-26-2003 04:31 PM
which clutch ?? madgts4 Performance 5 09-05-2002 01:44 PM
Which clutch should I get ? rOaD bEaSt Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 11-21-2001 07:12 PM
