Old 09-04-2003, 02:41 PM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
NEWS FLASH! Hydro Conversion Kit Is OUT!!!
The Kit is out from Hasport. Will only work with current billet mount set. If you already have the billet mounts, you can purchase just the mount and linkage separately.
It is very easy to install. If you have a full B18B/C or second gen B16A changeover you will need to use the first gen rear bracket and bracket on the driver-side of the engine. The rear bracket needs the holes enlarged to accept the 14mm bolts that go from the tranny to the rear bracket. It uses one of the existing studs the other one is removed. And you will also have to buy the trans mount.
Axles haven't changed, but if you use the 90-93 Integra or 89-91 SiR intemediate shaft you will need the change the seal where the shaft goes onto the hydro transmission.
*A lot of information given here taken from Brian G. of Hasport.
Old 09-04-2003, 03:25 PM
SiZ's Avatar
SiZ SiZ is offline
That is fucking awesome news!!
[starts looking for an ITR tranny]
"The nympho of info, I'm fuckin' what ya heard"
Old 09-04-2003, 03:39 PM
Re: NEWS FLASH! Hydro Conversion Kit Is OUT!!!
figured you would be one of the first ones interested. Im already ahead of you in the search though
i have a supplier
Julian
Old 09-04-2003, 08:21 PM
SiZ's Avatar
SiZ SiZ is offline
Ya, and I'm broke as fVck right now.. My car is smashed again and I'm selling my rims so I can afford to fix it..
BUT if I come across an ITR tranny this winter I willlllll be picking one up.. Mmmm.. S1 gearing without the grinds + an LSD.
740 with Ford 302 conversion kit- converse? johnnyg2 780 1 09-08-2007 04:36 AM
740 with 302 conversion kit- converse? johnnyg2 General Discussion 0 08-10-2006 03:23 PM
difficulty of cable to hydro tranny change out? tenz0 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-17-2004 07:06 PM
cable to hydro conversion. hmmm question! 95mr2 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 12-21-2003 03:22 PM
how do you do a hydro conversion? 97Sol Engineering/ Technical 1 10-11-2002 06:41 AM
