Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 09-01-2003, 09:55 PM
dibrager dibrager is offline
Question Which is a better engine? 22R or 22RE
My son asked me to find the answer to the question of 22R or 22RE as being better. Personally, being a computer/hypnosis geek, I don't have a clue what the answer is, so I post this as I hope someone with experience can avail an answer.
Thank you for considering the question.
Peace,
David
Old 09-01-2003, 10:25 PM
sk8nbroslofski sk8nbroslofski is offline
Send a message via AIM to sk8nbroslofski
personally i would go with the 22RE. fuel injected compared to carbureted.
Antyoo Antyoo is offline
well, fuel injection tends to be more efficient and easier on the engine.
both in the end can be made to have the same power, but the 22re would probably run more smoothly
Old 09-06-2003, 11:30 AM
killasoundz killasoundz is offline
for all out race engine they are about even. for a street car an all out race carbed 22R can still be used but an all out race 22RE wouldnt be as practical (bumpy cams make idle suck and bigger injectors will make mpg just as bad if not worse than the carb). but if you plan on ultimate power the 22RE is the way to go. its so much easier to turbocharge or supercharge. and the main reason im saying carb is a bit better for street is because you can do the hybrid (20R head 22R block) but if you tried to do it with the 22RE you have to go with double row timing chain conversion if its a late block. the 22RE intake will not fit on the 20R head so either you have to do extensive mods to the head to make it fit or make a custom intake manifold (big $$$ if you cant do it yourself.) plus there are many people pushing about 230hp+ out of N/A carbed (dual webers, mikunis, etc) hybrids and ive never heard of anyone pushing those numbers out of a FI hybrid or even a 22RE.
1979 celica GT 5speed
ww.classic-celica.com
Old 11-08-2003, 01:08 AM
82crawler 82crawler is offline
The 22re has about 10 more stock HP......
The ultimate NA 22r*
85+ Block
82-84 Domed Pistons...
Hybrid 20r Head with 22r Valves (over sized)...
Offy Intake with Webber 32/36 Carb...
LCE Headers....
High compresson and good till about 7k RPM....
Old 11-08-2003, 01:16 AM
Some Links for you....
22r-e (racing heads/cams)
http://www.engnbldr.com/ToyotaHotLicks.htm
22ret
http://www.well.com/user/mosk/
22r Specialist...
http://www.lcengineering.com/
Old 11-13-2003, 10:54 PM
oldbluecelica's Avatar
oldbluecelica oldbluecelica is offline
Send a message via AIM to oldbluecelica Send a message via MSN to oldbluecelica Send a message via Yahoo to oldbluecelica
Re: Which is a better engine? 22R or 22RE
dude, when i doubt, go with injected!!
which would be a better engine for my truck? FastTeen F Series 5 06-05-2004 08:18 AM
whot chice is better? engine or turbo for rs yuraRS Off-Topic 13 02-28-2004 03:51 PM
Whats the better engine? RedRacer Integra 10 07-13-2003 08:40 PM
looking for a better engine spdracr87 '71-'87 Civic | CRX 6 06-12-2003 10:38 PM
cOSTS of a b16 or better engine 87accord Engineering/ Technical 0 03-29-2002 02:17 AM
