Old 02-27-2004, 12:30 PM
yuraRS yuraRS is offline
Question whot chice is better? engine or turbo for rs
hi, i have 97 rs and want to make some upgrade and thinking to put aturbo in or change the engine to 4g63t. which option is better? and if i put turbo in do i have to change computer and make some upgrades to engine?
Old 02-27-2004, 12:41 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
the swap will most likely cost you twice as much as if you turboed it! i would suggest putting a turbo on it to start... then if you want to boost more then do some upgrades with the internals! you can turbo your car for under $2000 if you know how to work on cars... if you dont it will probably cost 500-700 more, let me know if you have any other questions!
Old 02-27-2004, 12:59 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
personally i like turbo more than anything. just by listening to the sound of the BOV makes it so much sexier than any other cars
Old 02-27-2004, 01:02 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Save up the money to get a gst or a gsx because it would be less than the engine swap. If your worried about insurance then turbo the rs. Either way you'll have save up a good amount of money.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 02-27-2004, 02:47 PM
hey ducky, how tall is your wing and how wide.
Old 02-27-2004, 03:01 PM
EclipseRST's Avatar
Banned
lol... thats not his car!
Old 02-27-2004, 05:04 PM
Re: whot chice is better? engine or turbo for rs
ok if i will put TURBO in my car how much psi is not too bad for rs engine? and do i have to upgrade computer? and if you know where i can get turbo cheper it will help to. thanks
Old 02-27-2004, 06:00 PM
duckydsp's Avatar
I only put that car on my avatar cause it has my body kit on it. It's definitely not mine. To turbo the rs you would need a lot of extra parts to upgrade you engine. With the 420a, I wouldn't go over 10psi until the engine is strong. Eclipserst is the expert on turboing the n\t. Also Hahn Racecraft usually has the best turbo kit. The only kits I seen are star, hrc, and jackson racing which are all around the same price range.
DSF
Old 02-27-2004, 06:16 PM
whot kind of "extra parts" i will need to upgrade?
Old 02-27-2004, 06:44 PM
duckydsp's Avatar
A lot of those extra parts would be internals such as cams, piston, and others like longer head bolts which eclipserst has warned us about in the past. You would also need a new fuel pump, lines, fittings and even more things. There are millions of threads that go through all of this. Just do the search and there will be more than enough answers.
DSF
Old 02-27-2004, 07:19 PM
so isnt it will be easier just replace the engine for a turbo one?
Old 02-27-2004, 07:28 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
You decide....(from 2gnt)
1. 4G63 turbo engine (stock)********* $1500
2. transmission (stock GS-T FWD)***** $500
3. wiring harness for engine********* $300
4. 4G63 ECU (stock)****************** $300
5. shift linkage********************* $200
6. custom engine mounts************** $200
7. chassis cross member************** $100
8. complete exhaust****************** $200
9. intercooler, turbo, related parts* $500
10. boost gauge/fuel filter, etc***** $300
11. Installation******************** $1500
This totals $5600, and doesn't include unforeseen obstacles in the installation.
For Sale 98 Eclipse GS, 5 spd
Old 02-28-2004, 03:15 PM
duckydsp's Avatar
To run a 4g63, you would also need to gut the engine bay because the 420a is on the driver's side while the 4g63 is on the passenger side. The intakes are on opposite directions.
DSF
Old 02-28-2004, 03:51 PM
EclipseRST's Avatar
Banned
too add to ashah's post.... if you really want to do the swap, keep in mind another thing, then car will be stock still... even after that 5600 that you spent on the swap, now you put that 5600 into the 420a and you have a fast as hell sleeper your choice i guess but i would spend your money and time wisely! just my
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
