Old 09-01-2003, 08:28 PM
wraith2003 wraith2003 is offline
Need help removing radio. Plz Help
I am new to this website but I need to know how to remove the radio from my 97 Grand Am GT. I have the left side of the instrument panel removed but the part that goes over the radio wont come off. I don't want to pull on it to hard because I'm afraid of recking something. I was told to remove the accessory trim plate but I don't know what it is and how to remove it. Please help me out.
Old 09-12-2003, 02:02 PM
mikail66 mikail66 is offline
You probaly have already thought of this but if you grab a haynes amnual or other kind and have a look. They will usually show some pictures of how to dismantle your dash. If you dont want to buy one just go to the library.
Good Luck and enjoy your tunes
Old 10-01-2003, 08:33 PM
mike_drz mike_drz is offline
radio
Are you sure u removed all the screws, even the two that are in the small compartment u know the little compartment just above the center console? I removed my radio recently to put in a new one, taking off the plastic wasn't really the hard part, it was rewiring the new one. Neways once you get all the screws off just pry it upwards and it'll pop right out of the above plastic dash piece. Just becareful not to pull forcefully on the left side cuz there's a small wire there that's connected to the light dimmer.
Old 11-25-2003, 03:27 PM
Gregzilda Gregzilda is offline
1997 grand am
If you try to take out the radio before disarming the passlock feature you will regret it. Not only will the old radio never work again in another car but you will set off the theft system and your car will die after a few seconds whenever you try to start it. Get a repair manual, call the service department at the Pontiac dealer and ask for directions or have a professional take it out to prevent trouble. By the way, a lot of radios have locks on the side that require a narrow flat tool to be slid in to disengage the locks before the radio can be slid out. Do this only after understanding that there is a certain combinations of radio buttons to push in a certain sequence before the radio can be removed safely.
Old 12-09-2003, 05:24 PM
98GrandAm 98GrandAm is offline
Re: Need help removing radio. Plz Help
Disreguard what greg said. This will not happen with a 97.
Old 12-13-2003, 11:09 AM
davidmcc davidmcc is offline
Send a message via Yahoo to davidmcc
Will this happen on a 96? I am wanting to replace my cassette player with a stock cd... will I have to do something special?
Old 12-13-2003, 03:10 PM
nope, It will work fine. Just make sure that if you have a red blinking theftlock light on the tape radio when the vehicle is turned off, that you disable the theftlock before removing the radio. Instructions on how to do this are in your owners manual. If your radio has a blinking red light on it when the vehicle is off and you dont remove the theftlock, the next time you connect that radio in your vehicle it will be inoperable until you find the code to disable the theftlock. If your radio does have that red blinking light and you dont remember the code to disable it for you, i can help you look it up.
AM radio reception problems--WHAT do I do-- I need my Talk radio--Please help 99jetta '97 - '03 3 10-22-2005 03:38 PM
help removing radio from 1991 Ford Escort starjan Escort 5 08-24-2005 07:29 PM
NEED GLASS & BEARING PLZ HELP!!!!!!!!!! nite53 Storm 0 01-02-2005 07:38 AM
Need Engine In Melb Plz Help! vinsalor JDM Motor & Parts info/chat 1 12-04-2004 01:00 PM
Please Help Remove Radio On A 1996 Passat momoneyrecords '93 - '96 1 12-15-2003 09:04 AM
