Old 09-01-2003, 12:25 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
struts: confirm/correct what ive been told...
I was told that you can tell if struts are bad if when they are off your car and together with the springs if u push down on the strut and it comes back up very slowely, is this true??????????
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 09-01-2003, 12:49 AM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
easiest way to tell if a strut is bad....go to one corner of your car...push down on the car....the car should raise once...go down once and raise one more time and stop....all on its own. if it does the struts are good. hell why would you want to remove the struts to tell if there bad...also look at the tires....feathering of the tires may also lead you to beleive the struts are bad....sometimes not.
Old 09-01-2003, 01:23 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Re: struts: confirm/correct what ive been told...
Best way to tell is to take it to a suspension specialist and get it up on their machine that simulates bump and rebound - it's also pick stuffed joints etc. It's a free service over here in a lot of places. Otherwise, depress and it should rebound then return to neutral.
Cheers
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 09-01-2003, 01:34 AM
BullShifter's Avatar
If they are off the car like your talkin' & you can compress them, they should return to the same posistion - not fast / not slow - nice smooth stroke
Old 09-01-2003, 03:18 AM
91civicDXdude's Avatar
my brother took the struts off the front of his civic, well, they were just compressed. you could pull the smaller piece out of the other piece, it would just fall back in. they were obviously bad
im running on 5 out of 6 cylinders?! so ive been told shawna82 Monte Carlo 2 11-27-2006 02:04 AM
Ive been told the same thing... imprtchk21 Off-Topic 3 10-20-2003 12:27 PM
What Ive been working on.. Camber WIP - Street 7 10-11-2003 06:02 PM
what ive been doin spididdy Graphic Manipulation 11 09-27-2003 11:49 PM
