Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-26-2006, 05:37 PM
shawna82 shawna82 is offline
Question im running on 5 out of 6 cylinders?! so ive been told
my 1996 monte is running like crap!! it has NO horse power when it takes off...it seems like it hesitates when i try to take off. its killing my gas milage. the rpms run rough (jump around) when idling...
i was told it was a spark plugs that could be dirty?!...the wires have been replaced along with the ignition coiles..
ive been to autozone and got a diagnostic reading and it kept saying cylinder 4 misfire... my uncle replaced the fuel injector for #4..it runs beter than it did but its still extremely unsatisfactory!!!!!!!! does anyone have advice? PLEASE HELP ME!!
Old 11-26-2006, 05:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: im running on 5 out of 6 cylinders?! so ive been told
Did you check the spark plugs? The wires? The coil pack?
Being a constant #4 misfire (P0304), my guess is either ignition or mechanical. If it's ignition, then plugs and wires should fix it. If it's mechanical, that's a sign of damage somewhere. Could be a burned valve, blown head gasket, and/or warped cylinder head. Has it been overheated? There could also be a vacuum leak in the intake manifold gasket causing this - is there any signs of water in the oil (either gray or light brown milkshake-looking stuff, water on the dipstick etc)? These 3.1 engines do have a problem with intake gaskets. The only thing that would lead to me not thinking it was the intake gasket would be that it's happening on the center cylinder on the back of the engine.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-27-2006, 02:04 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
The rough idling is a sign of needing a new Ignition control module.
