Old 08-31-2003, 09:03 PM
pre pre is offline
What do you think my 1/4 mile time would be?
I have a 87 Firebird with the following
V8 305, 4 Speed Automatic
42,000 miles
Computer Delete
Edelbrock 600 cfm Electric Choke Carb
Edelbrock Performer Intake Manifold
14" Open Air Cleaner, KN air filter
Comp Cams Roller Cam 260
Comp Cams Roller Lifter
GM Aluminum 1.5 Roller Rocker Arms
New Springs and Retainers
Double Roller Timing
New water pump
Edelbrock Headers and Y pipe
High Flow Cat
Hooker Cat Back
Auburn POSI with new ring and pinions
Stock 2.73 gears
BM Megashifter(rachet)
165 thermostat
Fan on at start
New HEI Distributor set at 35
I'm thinking the HP at the rear is at 210 and about 300 Torque
I Believe the car is around 3200 lb
O and I have regular tires on it
running 89 with Octane booster
Old 09-01-2003, 12:14 AM
krebs128 krebs128 is offline
Send a message via AIM to krebs128
well my friends '89 firebird w/ a 2.8L v-6 ran mid 16s, so i would imagine low 15's high 14's-"and i base this on absolutely nothing"
Old 09-01-2003, 03:26 AM
petereggy petereggy is offline
i am guessing low 15's because my friend has a 5.0L mustang with 225 rwhp and 3.50:1 gears and he ran a best of 14.8 but his clutch and posi need replacing
so very high 14's or low-mid 15's is what you should expect to run but only if you replace your gears
Old 09-01-2003, 10:38 AM
pre pre is offline
AFR heads
I'm thinking if I drop a set of AFR 180cc heads that will add about 50 hp
Old 09-01-2003, 01:30 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
Go out and run it and find out, any guess is a shot in the dark at this point...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 09-05-2003, 08:13 PM
Rakshas Rakshas is offline
Check mine.
84 Trans am.
305 v8 80,000 miles.
4 speed automatic
I'm thinking of putting a ls1 or a 383 stoker in there as well.
Old 09-06-2003, 06:43 PM
bkfirebird's Avatar
bkfirebird bkfirebird is offline
Send a message via AIM to bkfirebird
Good luck on running the 1/4 I'd guess High 14s, let us know and you should deffently put those heads on, they will make a noticeable difference
T/A Racing
91 Firebird / 85 Virago / 89 Silverado
check out my cardomain page]My Cardomain Page
It's great to talk shit before being smoked, but to talk shit after is just ignorent
Old 09-06-2003, 06:54 PM
FAPhoenix's Avatar
FAPhoenix FAPhoenix is offline
Send a message via MSN to FAPhoenix
Unless you've really reduced the weight your car is much more then 3200lbs.
I drive a 68 Firebird curb weighted at 3317lbs I'm 152s and it tips the scales at 3660 with a full tank and all fluids. You're car is curb weighted 3490lbs it is probably around 3700-3800lbs at track.
Do you have a torque convertor on it? That and a gear change would probably help track times more then new heads (for now).
Don't forget to brush up on your launch techniques, I think there is a forum here where you could read up then practice on some highway (Just the launch not the race).
PS Please don't drive through the burnout box unless you're running slicks, you'll track water down the track.
Old 09-07-2003, 01:22 AM
pre pre is offline
Thats a pretty high curb weight are you sure thats not for a 87 Trans Am 350 TPI with all the premium stuff on it. If your right about the weight I don't really care. What I really wanna know is if you guys suggest any other mods besides gears, heads, and torque convertor. How much would a 3.73 gear kit cost and to install it? Does $1000 to install a set heads seem too much?
Old 09-07-2003, 01:51 AM
FAPhoenix's Avatar
Well weight is the easiest way to drop time. 150lbs is 1/10 in the 1/4 mile.
$1000 just to install seems rather high, but I do my own work on my car so I'm not sure the going price. I think you could probably install the heads yourself with a few days and some help. A good Chilton's manual would be a must.
That is a high curb weight, it wasfor a Trans Am, but I actually went light on the guess to counter that for your car. Trans Am was around 3880lbs or so.
Gears:
4.10 Gears here:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2430536032
They seem reasonable but I don't know too much about 3rd gen birds. If I was going to bid I would just do the "Buy Now".
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2430564695
Same speel as above, but ask for a picture without a card in the middle before bidding.
Going 4.10's will definatly increase off the line power a lot and feel really nice. So unless you like to fly down the highway at 140mph its probably fine. Remember with OD it'll be like 2.87 rear gear which will probably still hit 140mph wound right out. (I can do 130mph with a 3.23 68 350).
I wish gears were that cheap for my car lol. (I need a full carrier/posi/gears just to go to 3.36+)
What 1/4 mile times you think I'll run when I get my mods in (Whenever that happens) Savior1974 Off-Topic 14 10-29-2004 06:46 PM
Do you think our 4th generation firebirds would be a good investment? i want a dirtybird Camaro Discussions 9 07-04-2004 05:16 PM
What Should My 1/4 mile Be? KyleSx5 Camaro Discussions 7 03-20-2004 11:28 PM
whats you guys 1/4 mile times youngvr4 Off-Topic 15 02-02-2004 07:57 AM
What is a respectable 1/4 mile time/speed? PhatBastard Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 05-23-2002 04:47 PM
