Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-27-2003, 11:02 PM
A_C_U_R_A-GSR-97 A_C_U_R_A-GSR-97 is offline
Which Exhaust System is WAY Better?????
Skunk2 Exhaust System 8HP Gain!!!! $499.00
Skunk2 Racing cat-back systems are constructed from T-304 stainless steel and feature Japanese Super N-1 design and styling. Each exhaust is mandrel bent using properly sized tubing for maximum flow and is finished off with a low restriction racing muffler. All mufflers feature a single 102mm polished tip with an acid etched Skunk2 Racing badge. Systems are available in Standard (half polished) and Polished. Each system comes complete with a removable silencer and all necessary hardware. Skunk2 Mega Power universal mufflers are also available separately
OR
Tanabe Super Racing Medalion Exhaust Systems $525.00
Bursting off nominal Rs! Tanabe's Racing Medalion is a straight layout with minimum bends and bending angle, and forceful silencers most fit heavy bass noise and high power! Lately nominal Rs are too many. Naming a muffler with an R doesn't make the car faster. There are many conditions required for R being R. Medalion - is released with honorably named "Racing" for the first time by Tanabe. It contains long-standing know and technique. Racing Medalion - 14 years were taken to complete it -is the ultimate high performance exhaust system with spec. Tanabe only allows to name with Racing
And does it matter if its 3" or 2.25" mandrel bent stainless steel pipe or not...which gets you better HP Gains??? Is it WIDER is better???
If you drive slow, STAY DA FREAKIN' OUT MY LANE!!!
1997 ACURA Integra GS-R
3" PVC Intake
Test/Straight Pipe
***SOON***
AEM v2 CAI
Random Tech Hi-Flow Cat Converter
A'PEXi N1 Series CatBack Exhaust Sys
DC Sports 4-1 header
Old 08-28-2003, 06:43 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
you'll get the best feedback by doing a search... exhaust questions aren't that uncommon around here.
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 08-29-2003, 03:57 AM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
I have a 5zigen fireball, I love it
Darrell
thegrumpysergeant.net
Old 08-29-2003, 08:32 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
well if price isn't affecting your choice then here are a few things to look for i suppose...
~stainless steal is a plus
~less bends the better
~umm i'm not sure but isn't 3 inch piping a little big for this application? i would think 2.25, or 2.5 would be best?
~decent welds, I looked at a muffler the other day that wasn't even welded together the canister was only riveted together!! sounds leaky to me...
anyway thats just a few things to keep in mind. if i think of more i'll let you know.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 08-29-2003, 01:03 PM
CryptzKilla CryptzKilla is offline
Read articles at team-integra.net to get a better understanding on exhausts and many other things as well.
Old 11-11-2003, 11:03 PM
Spoontyper95 Spoontyper95 is offline
Re: Which Exhaust System is WAY Better?????
i agree with them^^^
J. Jurac
Old 11-11-2003, 11:33 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
i always thought 3 inch piping was a little big for n/a applications
isn't 2.25 ok?
Old 11-12-2003, 12:27 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
3" piping is for turbo apps
2.5" is for naturally aspirated v-tec engines (b16, b18c1, b18c5, b17...)
2.25" is for naturally aspirated non v-tec engines (b18a1, b18b, d16..)
you'll lose so much low end torque if you get 3" piping for a naturally aspirated non v-tec....
Old 11-12-2003, 06:21 PM
shaunthebadass shaunthebadass is offline
Send a message via AIM to shaunthebadass
skunk 2 exhaust is the best.........no competition
Old 11-12-2003, 10:10 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
for a n/a motor, its not going to matter much on brands.
jus make sure u don't get anything over 2 1/4 in an u'll be fine.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 11-12-2003, 10:16 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: Which Exhaust System is WAY Better?????
maybe 2.5 if you have some crazy cams and head work but only if you have these, otherwise 2.5 will be robbing hp
Old 11-13-2003, 06:09 PM
the only reason i said skunk 2 is cause most others sound like shit......i HATE when someone has a shitty exhaust....this and greddy are the only two that sound good if you ask me.......some people say n1 is good but i heard it on a ls/vtec and it got high-pitched at high rpms, not cool
Old 11-13-2003, 06:15 PM
whtteg's Avatar
Man I need to get a sound clip of my exhaust, I swear the Vibrant system sounds really good, not high pitched at all , and not harsh ricerish either. I will see if i can get a sound clip up soon.
Old 11-13-2003, 08:29 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
if u can afford, i say go for spoon
Old 11-13-2003, 09:01 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
Greddy is pretty high pitched to me. I havent heard much else(that I actually know what brand/kind they are I mean). Vibrant? what do those go for?
Can better Exhaust System give better MPG? sad-lumina-owner Engineering/ Technical 4 08-01-2008 09:36 AM
Can better Exhaust system give better MPG? sad-lumina-owner Lumina 2 07-23-2008 03:04 AM
Which Exhaust System should I get Zero260yes Avenger 28 11-27-2004 05:05 PM
Which clutch system is better RalphCare 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 10 07-23-2003 06:44 PM
Which exhaust system JayFidizzy '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-28-2002 10:18 AM
