Old 08-25-2003, 10:32 PM
caminsc5 caminsc5 is offline
Send a message via AIM to caminsc5 Send a message via Yahoo to caminsc5
zc question
i just installed the zc in my 89 crx si....and i think i have my vacuum hoses hooked up wrong, im not sure. im not sure which goes where or connects to what. does anyone have any pics or advice?
Old 08-25-2003, 11:26 PM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
where in greenville you at? im in salem nc...ill be in spartanburg this wed and thur.....maybe i could take a look. if anything mail me at [email protected] i couldnt help you really with out seeing whats hooked up and whats not.
Old 08-25-2003, 11:27 PM
im right off 291 (pleasantburg dr)
Old 08-26-2003, 02:33 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
type out what you got going where, got a zc in my hatch and its running good, id take a pic but my camera cant get sharp images of anything up close so it wouldnt help
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 08-26-2003, 01:04 PM
89 crx si -standing facing the engine-
ok i tried to go see where the hoses all were going and this is what i came up with: (forgive me if i dont know the technicals terms lol)
-i dont have a hose connecting to the big plug on the valve cover (i know a hose from the intake goes there, just dont have an intake yet).
-i have nothing connected to the "L" shaped plug (it resembles an L, but it comes out a lil and bends to the right). its to the right of where the throttle cable hooks in.
~~the 2 black bottle looking things that are mounted on the firewall & have hoses comming from the~~heres where the hoses run:
-the bottle thing on the right, its middle (or side) hose is ran to the top piece of the lil black round cylinder thing.
-the bottom hoses of the 2 bottle things are connected with a "Y" shaped connector. and then it has a single hose that runs to the plug on the throttle body (the plug is the farthest left, the plug is in between the P and G in PGM-FI)
-a hose attached to the bottom of a screw looking thingy (to the right of the bottle thingy) has a hose connecting to a "Y" connector. and connects to the side hose on the left bottle thingy. and that has a single hose that runs to a plug behind the intake, right behind where the throttle cable hooks in.
i hope this helped some, i tried explaing clear as i could. thanks alot
Old 08-26-2003, 01:08 PM
i have the si ecu for now, but the zc is being shipped as we speak.
it idles real low (bout 500 rpms)
and it has a small oli leak, just need a new oil screw
Old 08-26-2003, 03:57 PM
ZCDOHC94hb ZCDOHC94hb is offline
Re: zc question
How did you hook up the purge valve (vacuum hose that comes from charcoal canister)? Did you customize the throttle body or...????
Old 08-26-2003, 05:29 PM
94tegRS's Avatar
ok, this is as detaield as i feel like getting right now
on my car I only have one black canister on the firewall, and it has 3 hoses, on about 3/8" and thren next to it a 1/2" hose with a 1/4" right above it. on my throttle body right next to the MAP sensor there is a fitting that goes to the 1/2" hose on the canister. the little 1/4 inch one i got going nowhere cuz i got no where for it(anybody wanna tell me where it goes?) the 3/8" one that is by itself on the canister, if you follow it runs into a metal line, and if you follow that it makes its way over to the drivers side and goes under the car, where the 3 hoses are, the middle one comes from the fuel rail, the drivers side one is where the 3/8" hose goes. on the intake manifold, on the side facing the valve cover, there is 2 fittings, the smaller one goes to the top of the fuel pressure regulator, and the larger one goes to a fitting that is inbetwen the 3rd and 4th runner close to the head. and on the back of the intake manifold there should be a large, about 3/4" hose going to the brake booster.
those are all the hoses i got involving manifold, throttle body and canister. but my car is a 94 hatch, so I dont knowq how close your car is to mine, and i am pretty sure it is the ZC's manifold cuz I got one from a LX and was gonna put it on and it wouldnt have bolted up, but maybe the throttle body is the stock CX throttle body, in which case your MAP might be different, maybe the kind that comes form the back of the intake manifold.
current
history:
Old 08-27-2003, 12:14 PM
You have the same problem
The hose that you have hanging is the one that goes to the purge valve. I don't know exactly what it does, some sort of emissions control system. I believe our cars are very similiar, if you look on the inside of your hood (providing it is still stock) there is a picture of the vacuum routing system. I don't like that hose hanging out and was trying to figure out how to get it hooked up properly. thanks for the reply.
Old 08-27-2003, 06:30 PM
94tegRS's Avatar
I got a replacement hood, ande absolutely no emmissions controls under my hood either. at least none i know of
current
history:
Questions,Questions,Questions.... r_c_inicial Mustang Talk 11 08-23-2005 08:26 PM
Questions Questions and more Questions H22silverbullet Prelude 15 07-30-2005 07:23 PM
Question Question Question Integra14 Car Modeling 2 12-07-2002 08:31 AM
