Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-25-2003, 02:58 PM
onehotcamry onehotcamry is offline
Send a message via AIM to onehotcamry
engine swap + turbo
hey all i have a 94 camry 2 door le
i am looking for possible engines here are some:
-IS300 but thats rwd so thats a lot of money putting it in
-celica engine w/ stock turbo
-toyota matrix, they only have 180 hp but maybe with turbo itll go up bit
any other ideas or suggestions would be helpful. or if ne one has done an engine swap into a camry lemme know. i also wanna change the transmission to a 5 speed or a 6 speed with the is300 if i were to get that. any help would be appreciated
-one hot camry
---also check out my site with my car @ www.freewebs.com/onehotcamry
Old 03-17-2004, 08:36 PM
Georgieo101 Georgieo101 is offline
Re: engine swap + turbo
Hey,
I too have a 2 door camry LE (96), I want to make it go fast, but it is ture, the camry has a limited supply of performance parts. Im sorry i can't help you, but i have a question for you. What engines will swap into a camry LE? and where did you find your exhust system (its tight!)
Old 03-18-2004, 02:47 AM
ToyotaTech ToyotaTech is offline
u guys are watching jesse james too much
Old 03-18-2004, 02:50 PM
Re: Re: engine swap + turbo
haha lol not really
if u go to toyotanation.com there are ppl that have swapped the 3s-gte motor (celica/mr2 jspec motor) in camry's. also u can do ne thing to a car w/ enough money.
i had a shop custom make my exhaust. its a catback dual exhaust cuz my bumber had dual slots. it was tight though. u even could just put a muffler on if u wanted too.
Old 03-18-2004, 05:47 PM
I noticed you had a cold air intake under the hood, i have been debating about getting one of these. can you notice the diffrence in hp? or is it not really worth it.
Old 03-18-2004, 09:14 PM
there isnt really a noticeable increase in hp, maybe a little. the intake really makes a lot of noise. it has a deep sucking sound when ur a WOT and it sounds pretty nice. almost sounds like a turbo some ppl have told me lol
Old 03-19-2004, 06:40 PM
AJ236 AJ236 is offline
Check Ripp Mods dot com. They have bolt on superchargers and stuff. You may come to find out (as I have) that an engine mod like that will cost you more than buying the same year Camry with the Six cylinder in it. Unless you already have a heap of cash in your ride, trade for the six.
Old 03-20-2004, 02:34 AM
Calebz Calebz is offline
I already have th V6 in my 94 XLE.. Need performance parts for that.. TRD makes a superchrger for the V6, but says its only for Gen 4 Camrys..any suggestions?
Old 03-20-2004, 08:25 AM
There is probably an aftermarket somewhere. I have seen them in passing for the V6, but since I have the little ol' I4, I just passed them by. But they are out there. Use an internet search engine for toyota tuning. I just saw a picture of a guys Gen3 V6 with a supercharger. Using that search engine. Some SC3 car club, southern califonia camrys club or something.
Old 03-21-2004, 03:40 PM
you guys should all check out ... this is the best website for toyota's
they also have a camry section w/ a lot of people.
check it out
No advertising of competitor's websites
Brian R.
Old 12-02-2009, 08:47 AM
needforspeed9's Avatar
needforspeed9 needforspeed9 is offline
hey i have a 1987 camry and it has no balls. i wanna drop a supra or an mr2 motor in it but idk how hard or expensive it is to do it. what would be a good and relatively easy swap to do?
Old 12-02-2009, 09:30 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
There is a discussion of Camry engine mods in the FAQ thread.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-16-2009, 12:57 PM
joshspeed joshspeed is offline
I would definately say that you don't want to try and put a 2JZE-GTE (Supra, IS300 motor) in your camry... not only would you have to cut or beat back the fire wall, but you would get into heavy cost of trying to find a new rear end, and change it out. Although I have always dreamed of making my '98 LE into a speed demon lol... And there is nothing wrong with looking into doing awesome stuff with your car... Useless, you think you are like Jesse James comments we could all do without... find another string to post on please... negativity is not needed or desired here.
Old 12-16-2009, 01:01 PM
You could see what other vehicles have the XLE motor in it, and see if any performance parts are made for that vehicle. Some things might need to be modified to work, but the priciple is there. I would recommend starting small with something like an underpulley kit to get a little bit of ooomph lol... you could also look into aftermarket chips, air induction products, and other small things to gain HP. I believe that an underpuller system will add around 15-25 HP, just by lightening the workload on the engine. Check it out....
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
engine swap/turbo/ls vtech??????? zr800efi JDM Motor & Parts info/chat 1 05-03-2008 07:18 AM
