Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-25-2003, 02:50 PM
mfmark5007 mfmark5007 is offline
Can this even happen?
Can you put a normal Cold Air intake and a Turbocharger together in an engine?
How does a turbocharger change the routing of exhaust and intake around the engine?
*anyone have a diagram?
Old 08-25-2003, 03:51 PM
Accord_Zero's Avatar
Accord_Zero Accord_Zero is offline
Send a message via Yahoo to Accord_Zero
Go to howstuffworks.com and check out the automobile stuff. They have a pretty hefty part on turbos, with diagrams. As far as how one works, the exhaust blows into the turbine housing to spin both ends of the turbo. The compressor side then blows air out and into the intake. A cold air intake can be hooked up to the compressor side, a filter is needed there anyway. It would have to be modified to fit though.
Just check out that site and you'll understand. It's a very easy concept.
Old 09-01-2003, 02:13 AM
hondatool hondatool is offline
but cold air intakes are hooked up to the throttle body and usually if you get an intercooler the other end of the IC goes in the throttle body which would leave no place for the cold air intake to go into ...
Old 09-01-2003, 09:32 AM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Re: Can this even happen?
Yes but he is saying on the COMPRESSOR side you can make a CUSTOM cold air intake. Simpley the turbo is pulling in air from outside the engine compartment. Alot of people do this on race cars for the obvious reasons, but fore most street apps you are better off pulling in air from a hot, and DRY engine compartment and then through an intercooler. You dont want a turbo sucking up puddles. The term "cold air intake" isnt just limited to those 3hp gain AEM things.
can this happen tractorboy Malibu 5 08-07-2006 08:43 AM
How can this happen? Gafoto Diecast Car Modeling 9 02-18-2003 03:40 PM
